Question about Siemens Washing Machines
Siemens e12 42
Dear Sir /Madam, my washing machine has a huge vibration during spin operation how can fix it? it is highly appreciated guide me best regards
  • Siemens Master
  • 3,247 Answers
I am unable to find a user manual for your model of washing machine. If it is a front loader then most likely the if you are not overloading the machine the following needs to be checked
1. level screws at base of machine are level with floor. Push the machine down from one side and see it lifts from other side. This needs to be correced.
2. slightly reduce the spin speed and see if it makes a difference
3. the counterweight on the drum may have come loose. This will mean opening the top cover and checking if the bolts holding the counter weight (block of concrete) are set properly.
4. Also check if the motor belt is not worn and is slipping.
Posted on May 06, 2014
SOURCE: Wash machine will not spin
sounds like a problem with the coupling between to motor and the gearbox!
Posted on Jul 16, 2007
Washer_tech
  • 164 Answers
SOURCE: washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Posted on Aug 16, 2007
  • 641 Answers
SOURCE: Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Posted on Sep 04, 2007
BADBOYJAY
  • 264 Answers
SOURCE: LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Posted on Jan 05, 2008
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
Frigidare Gltf1040as0
Good Afternoon Carrie,
I understand that you are hearing a loud noise in the spin cycle as well as water leaking from your Frigidaire washer, model# GLTF1040AS0.
You will commonly hear a high pitched "jet engine" noise during the spin cycle. If you are hearing a vibrating noise, it could be your washer is not resting firmly on the floor. With this you will adjust the leveling legs so the washer is level. If after leveling your washer you are still receiving a vibrating sound, you might want to redistribute the wash load inside your appliance.
If after you redistribute the wash load, you are still hearing a loud noise in the spin cycle, I suggest contacting a local authorized technician.
For the leak I recommend contacting a technician. This way they are able to find where the leak might be coming from and repair it before there is any damage done to your appliance. Hope this is helpful.
-Best Regards-
WP
Apr 29, 2014 | Frigidaire Washing Machines
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
LG front leader washing machine;high pitch vibration during spin, the house is vibrating with it, we can feel it at the other end of the house, any fix?
You can buy rubber pads at the home center that damper the vibrations.
The high pitch noise could be an object stuck between tubs.
WM2277 service manual
Mar 08, 2010 | LG WM-2277HW Front Load Washer
Knocking and rocking at lower spin RPMs
hi there......check that the installers removed all the transit bolts....these are used to hold the drum secure during transport....check that the balance weights on the appliance are secure.......
regards Sir Galahad
Aug 18, 2009 | Washing Machines
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
Out of balance drum WM2277HW?
More than likely it did not get reinstalled right after the move. All four of the leveling legs must be firmly touching the floor. If one is even the thickness of a piece of paper off the floor it will start to rock during spin and the problem just amplifies itself. Make sure it's perfectly level and that all the feet are firmly on the floor.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
Excessive vibration during spin cycle
If this is the only problem be thankful ,its capable of a future of problems. I my self would not recommend putting 1 more dollar into this machine.Your next concern is a high dollar repair that may be soon coming ,that is a circuit board problem.
Please rate this !!
Jun 09, 2008 | Washing Machines
Washing Machines Logo
232 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
