Question about Siemens Washing Machines
Error f43 in siemens washing machine - Siemens Washing Machines
  • 185 Answers
SOURCE: getting error code e:02 on
model number please
Posted on Mar 28, 2008
SOURCE: my siemens washing machine S14.39 keeps stopping a...
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
Posted on Aug 22, 2010
  • 6277 Answers
SOURCE: Washer machine Siemens model: WM
Here are my general guidance notes for a possible cure ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 28, 2011
  • 6277 Answers
SOURCE: Hello can you please help
For Bosch Logixx, F42, F43 and F44 all decode as 'motor fault indicated'. Sorry ;-0)
I changed the motor on our Bosch (not a Logixx) at a cost of GBP250! I do expect it to last another 20 years, though.
If this has assisted you please score accordingly.
Thanks and good luck!
John C
Posted on Apr 12, 2011
  • 6277 Answers
SOURCE: F18 error message siemens washing
For most models- you do not say which yours is- Bosch's 'F18' states 'drainage (filter) problem.
I advise you read through these guidance notes and check the filter AND the operation of the drain pump itself- it could be jammed.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
John C
Posted on Sep 12, 2011
My Siemens WM16S740AU IS displaying F43 and can bot do any tin
post this again and make sense by using full words in a well constructed sentence
Jul 30, 2016 | Siemens Washing Machines
F43 Error showing. Please help
The F43 indicates that the motor control detects a low voltage condition. If you have a volt/ohm meter and the ability to safely check the voltage at the dryer outlet, you can check for 120 volts at the outlet for the dryer. If the voltage is low or drops when the dryer is running, this would be causing your problem. You could have a loose wiring connection. If you are not completely confident in your technical ability to safely check the voltage at the outlet, I recommend calling a service technician to check the dryer.
If the outlet voltage is okay, you could have a wiring connection problem between the outlet and the control board of the dryer.
Jun 12, 2015 | Siemens WM14S794GB Front Load Washer
How to reset siemens washing machine?
what model of machine
F40-50 is usually something to do with the door lock interlock
Aug 30, 2014 | Siemens Washing Machines
Fault code to bosch washing machines f43
F43 normally indicates a fault with the motor or the main control board
Dec 22, 2012 | Bosch Washing Machines
F43 ON THE SCREAN
F43" error indicating "motor malfunction"
Oct 15, 2012 | Bosch Axxis WFL 2060 Front Load Washer
F43 ON THE SCREAN
Oct 15, 2012 | Bosch Washing Machines
F43
Hi.
If you have Bosch, Baumatic, or any other machine built by Bosch, then F43 is a motor issue:
Error F43 : Motor fault: do an emergency drain through the drain access in the front bottom side (see manual). Open door and check ig the drum rotates free when spin by hand. Disconnect power before performing maintenance.
Regards.
Ginko
Sep 14, 2011 | Washing Machines
Siemens washing machineS16.47 Error code F43
is it possible to bye a new dor for this maschine?
I manage to break it.
Jun 11, 2011 | Indesit W 123 Front Load Washer
Washing Machines Logo
87 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
