I have a audio interface : alesis io2express And headphone :Sol replubic I start a vocal recording and after that I listen to it but I found out the it give me a buzzing and like robotic sound I tried turn it lower volume it decrease but still and in the end I cannot listen well to my own recording and please solve this problem for me Thank you Please reply me as soon as possible
    New Friend:
  • 117 Answers
Sounds like you may be recording electrical interference from another electrical source as well while trying to record your vocals. Try unplugging other electrical devices that are in the area of your recording equipment, then try recording again. If that doesn't work, move your recording equipment to another location and try to record again.
Posted on May 16, 2014
3 Suggested Answers
  • 6 Answers
SOURCE: recording on cubase
Remember when recording in 24-bits, you have 8 bits EXTRA over 16-bit recording, per voltage sample.  This means that for each voltage step that would be recorded in a 16-bit recording, a 24-bit recording will take 256 steps!  In other words, the fidelity is MUCH greater, so even if your levels seem low, that can be OK, since you have around 100 dB of headroom to play with, and can increase the signal many times with acceptable fidelity.  What you DON'T want to do in digital recording is CLIP, which is a virtually unrecoverable fault in the recording.
Posted on Sep 06, 2008
  • 86 Answers
SOURCE: How do i get Cubase Le 4 to recognize and record my Alesis Io2
You may have a conflict with the onboard sound. If that is not turned off your card will not function.
Posted on Jan 08, 2009
Using a Tascam US 122 with Cubase SX, when recording vocals red light (clipping) on the Tascam and in the Cubase mixer, I need to know how to set levels on Tascam, so there will be no clipping on vocal...
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Feb 26, 2011 | Tascam US122 Audio/MIDI Interface with...
I have a st69 and every time I record, the vocals while recording sound very chorus like in the headphones, but they sound fine when I listen to the play back, please help.
Check the mixer settings to be sure you are not sending multiple mixes or effects to the monitor (headphone) output. The output used for recording does not necessarily have the identical sound sources and mixing path as the headphone, so make sure the headphone is monitoring the same signal as the recording output.
Feb 07, 2011 | Sterling Audio ST69 Microphone
When u export the track down too a wav.form and i convert it too mp3. if i listen too it in headphones i can only hear the vocals in the right earbud.
Well, did you run the vocals through a mixer and send to BOTH channels of the Lexicon Alpha? If you connect the mic to only one channel you will only get one channel UNLESS you process the .wav file and PAN the vocal channel into both channels when outputing to your MP3.
Jan 06, 2011 | Lexicon Alpha Personal Recording Studio
Jan 07, 2009 | Alesis IO/2 Portable 2-Channel/ 24-bit/96k...
I have an io26 firewire audio interface linked to my macbook. When i record in cubase le4n i'm only getting sound out of the left headphone and its seriously quiet. I have set the audio/midi settings to...
your audio are not in interface with your macbook it means to say, the common wire are not in the same connection. that why you only hear sound on your left headphone. in short your firewire audio is not compatible with your macbook. but you can rewire it with same audio plug. or replace the audio plug with the compatible one. when you do this, make sure that the common wire of your firewire audio and your macbook are in the same connection.
Nov 07, 2008 | Computers & Internet
Cant record vocals while listening to beat without the beat being recorded twice
i have the same probelm as da 1st guy,, when i record my vocals some how da beat sneaks into da mic too and fuccs it up.. seriously its ****
Jun 23, 2008 | Alesis Multimix 8 USB 8-Channel Mixer...
Headphone monitoring DP02
It was a bad phone jack adapter ... found another one, and it works fine. The DP02 ROCKS! I wish it had build in compression though - I am finding my vocals get too loud and too quiet at times. Maybe it does, I have to keep reading. So far, it does everything except the dishes :)
I started recording back in the 80s, and spent over $30K back then to get equipment that honestly doesn't do as much as this little machine. (I wasn't rich, I went bankrupt).
Jun 07, 2008 | Audio Players & Recorders
Tascam Us144 and Sonar3 problem!!!!
Try this experiment:  Record a click track on track #1.  Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks!  You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
Apr 06, 2008 | Tascam US-144 Sound Card
Delayed vocal
If you're recording to an audio program on your computer (e.g., Cubase), there typically is a slight delay in the tracks you record with the first one (such as a slight delay in the vocal when layering over the guitar track). ou can change the delay in the "Preferences" for the audio card in your computer or you can remove the delay manually.. I do the latter. I record using the Audacity 1.3.3. program on a Mac G4. I find that get a 0.3 second delay in tracks layered onto the first track. So, after I record a track, I cut the first 0.3 seconds froom the beginning of the track (I give myself at least 10 seconds of "dead air" at the start. and keep playing the tracks until they're synchronized. Takes a good ear, but really is the best way to synchronize the tracks.
Nov 10, 2007 | Alesis Multimix 8 USB 8-Channel Mixer...
Computers & Internet Logo
David Payne
David Payne
