Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
How do you turn it on. What are the settings - Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Why am I getting no emails on my tablet
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
  1. From the Home screen, open the Settings menu.
  2. Under Personal, touch Accounts & sync or Accounts.
  3. To turn on or turn off Auto-sync
    • Touch the switch at the top of the screen.
      HTC Sense Samsung TouchWiz
      1. From the Home screen, tap the Menu key.
      2. Tap Settings.
      3. Tap the Connections tab.
      4. Tap Data Usage.
      5. Tap the Menu key.
      6. Check/uncheck Auto sync data.
  4. Touch an account to adjust settings, turn on, or turn off sync.
    • MobileLife Contacts
    • Google (appears if set up)
    • Microsoft Exchange ActiveSync (appears if set up)
    • Others, depending on apps installed
  5. To synchronize all accounts manually, touch Sync all.
  6. Press the Home key.
Android 2.1 / 2.2 / 2.3
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Accounts & sync.
  4. Under General sync settings, turn on or turn off:
    • Background data
    • Auto-sync
  5. Under Manage account, touch an account to adjust settings, turn on, or turn off sync.
    • Exchange ActiveSync (appears if set up)
    • MobileLife Contacts / T-Mobile / T-Mobile Contacts
  6. To synchronize all accounts manually, touch Sync all.
  7. Press the Home key.
Android 1.5 / 1.6
  2. Touch Settings.
  3. Touch Data synchronization.
  4. Turn on or turn off Auto-sync.
  5. Touch an account to turn on or turn off sync.
    • Gmail
    • Calendar
    • Contacts
  6. Touch Menu.
  7. To synchronize all accounts manually, touch Sync now.
  8. Press the Home key when sync completes.
Feb 19, 2015 | Samsung Galaxy Cell Phones
How can I stop businesses from posting ads on my fb account/
Help Center
How do I turn my campaigns, ad sets or ads on or off? You can turn your campaigns, ad sets and ads on or off from your Ads Manager. If you turn off a campaign, it'll also stop all ads and ad sets in the campaign.
To turn your campaigns, ad sets or ads on or off:
  1. Go to your Ads Manager
  2. Choose whether you'd like to turn a campaign, ad set or ad on or off
  3. Find the specific campaign, ad set or ad you'd like to turn off
  4. In the Status column next to the campaign, ad set or ad, use to change the status to on or off
Keep in mind that when the status is blue the ad is on and when the status is gray the ad is off.
To turn your ads back on, you may need to turn on the ad set and campaign too. Learn more about the campaign structure.
More info
Get help for mobile apps and browsers
Permalink ยท Share
Sep 22, 2014 | Facebook Social Network
Presentation mode is off
Hello Nixon,
Below are steps to turn presentation mode on/off in Windows 7.
Turn Presentation Settings On or Off using Windows Mobility Center
1. Open Windows Mobility Center.
2. To Turn On Presentation Settings
A) In the Presentation Settings tile, click/tap on the Turn on button, and go to step 4 below. NOTE: This will turn on the presentation settings that you have set in step 4
3. To Turn Off Presentation Settings
A) In the Presentation Settings tile, click/tap on the Turn off button, and go to step 5 below.
4. To Change the Presentation Settings
A) In the Presentation Settings tile, click/tap on icon in the upper left corner of the tile
B) Change the settings for what you want when giving a presentation, click on OK, and go to step 5
5. When finished, you can close Windows Mobility Center if you like.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 07, 2013 | Dell Computers & Internet
Refrigerator does not turn off even when temperature setting is turned to lowest level. When setting is turned to off and than turned to normal setting refrigerator compressor does not turn on. Unplug
0dec7907-6dd5-471f-9821-90c9724966dd.jpgModel Number Locations What is the model number? Does the refrigerator cool normally if you leave the settings on normal settings? What dis you want me to see by your video of the control panel? I am here to answer your question once I have the model number All compressors will not start for a few minutes after turning off and then back to normal setting because the Freon pressures must equalize to allow the compressor to restart. Thanks Sea Breeze
Dec 10, 2012 | Refrigerators
MY asus pc continues to not wake up. I have to
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 15, 2010 | ASUS Eee PC 900 Notebook
Screen goes blank after a few minutes
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 14, 2010 | Dell Inspiron 1318 Notebook
Think pad t42 monitor keeps turning off. I tried changing power settings to never ... did not help still doing the same thing anything else I can do? thanks
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 02, 2010 | IBM ThinkPad T42 Notebook
My screen turns black
control panel---->power options--->change plan setting---> Turn off the display-never Put the computer to sleep-never control panel---->power options--->change plan setting--->advanced power setting -set hard disk "turn off hard disk after" to never -set Sleep "Sleep after" to never -set hybrid sleep setting to off -set hibernate after setting to never - set display after setting to never
Mar 21, 2010 | Google Android
Setting time and date
From the manual:
1. Press the MENU button to open the menu.
2. Turn the SET dial to select [SYSTEM] and press the
SET dial.
3. Turn the SET dial to select [T.ZONE/DST] and press
the SET dial.
4. Turn the SET dial to select the setting option that represents your time zone and press the SET dial. To adjust for daylight saving time, select the time zone with the * next to the area.
5. Turn the SET dial to select [D/TIME SET] and press
the SET dial. The year display starts to flash.
6. Turn the SET dial to select the year, and press the
SET dial.
• The next part of the display starts flashing.
• Set the month, day, hours and minutes in the same way.
7. Press the MENU button to close the menu and to
start the clock.
Jan 15, 2009 | Canon Video Cameras
How to set a deh-p4000ub car radios clock
try this:
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
the clock display you wish to set.
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
You can turn the clock display on or off.
! Even when the sources are off, the clock
display appears on the display.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Aug 05, 2008 | Pioneer Audio Players & Recorders
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
