Question about Toshiba Satellite Pro 490CDT Notebook
Bios access I can't get into the bios to change startup sequence by using del or f2 key. any other options to do this? George
  • piper77 Nov 04, 2007
    instant sucess!!!!!!!!!!!!!1 thanks very much
    Sergeant:
  • 324 Answers
You might try this- After you turn power on, hit escape right away, then hit F1. That may get you to your bios screen.
Hope this helped!
R-
Posted on Nov 04, 2007
Where are the bios settings located?
Depending on what make & model of computer you have, right after the first beep during boot-up you will need to hit the "DEL" key or a function key. Watch the screen closely during boot-up and you should see a message that says "Hit DEL during startup to access BIOS." Dell computers usually use the "F2" key. You may have to tap it a few times to get into the BIOS. BE CAREFUL when you change settings in the BIOS. You can make the computer stop working if you change the wrong settings.
Aug 30, 2015 | Computers & Internet
How do I access bios on Compaq 8620s
Compaqs use different keys to access BIOS; try F2, F1, F10.or DEL. At the pause on startup there are usually instructions at the bottom of the screen telling which key to press for access to BIOS.
Dec 25, 2013 | Compaq Business Notebook 8620s Laptop...
How can I change boot sequence in Compaq Evo N410c?
You need to access your BIOS configuration. 1. To do this, shutdown your computer and boot it by pressing the power button. 2. You need to hit F10 when the computer first powers up in order to get into BIOS (Note that the key is usually different for different computers. If F10 doesnt work, try F2, F12, Delete or F9. 3. Once in the BIOS, you should find the boot sequence option.
Hope this helps!
Apr 11, 2011 | Compaq Evo N410C Notebook
Cannot boot from cd and run setup
When booting, the writing on the black screen should give you a couple of options akin to
Press F2 to edit boot options or
Press "Del" to enter setup. (bios)
You can use either, but you need to set your CD/DVD disk drive as the first boot option.
May 04, 2010 | Microsoft Windows XP Professional SP2
I have a durabook R14K, i need access to bios, how do i do
Usually you can acces BIOS by pressing
"DEL" Key duing system startup.
But it also depend on the BIOS manufacturer and version on how to access BIOS
I'm giving you all the key which normally used to access BIOS.
1.DEL
2.ESC
3.F1
4.F2
5.F10
6.F11
7.F12
8.ESC+DEL
try them ,it will surely let you access BIOS.
Jan 02, 2010 | Twinhead Computers & Internet
I need to access the BIOS on my Gateway GT5428 PC
well, the most common BIOS entry keys are F1, F2, F10, and Delete.
push one while the computer is booting, before windows starts booting.
Mar 26, 2009 | Gateway Computers & Internet
Which key to press at startup to gain access to BIOS E2180 Intel
There are a number of keys used to access the system BIOS at startup. F2 is probably the most common, but I see you've already tried that. I've also seen the ESC and DEL keys used, so try those. If that doesn't work, start working your way across the F1-F12 keys.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 13, 2009 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
How do I Access BIOS screen in a IBM PII-6862-84U?
As the computer boots press the DEL key to access BIOS
note: some systems you must press F2 or Esc
In BIOS under the BOOT tab options change the Boot order so that the CD drive is First
Select EXIT and Save Changes to reboot
note: make sure the CD is in the drive BEFORE you reboot!
(it sounds obvious but a lot of people forget)
If the CD is bootable it will start its own boot sequence.
Feb 21, 2009 | IBM I System Board (61H2600) Motherboard
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite Pro 490CDT Notebook Logo
124 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
