Question about Siemens Washing Machines
How to deaktiver bornesikring in a
Listed on its screen. i have no access to any other program
How do you fix the sound
Assuming youve checked every volume slider there is (the one in whatever program your using, the one on the bottom right corner of the screen by the clock, and the master volume.....
Thab go to your start button on the bottom left of the screen (where you normally access all your programs), there should be a little "search bar" on the bottom of that list. Type on "device manager", scroll down the list and locate your speakers, right click and than go to properties. First try "update driver", if that doesn't work than click "Uninstaller driver" and restart your computer. That should do it.
Dec 13, 2014 | Audio Players & Recorders
How can i use my web cam
Your Dell Latitude E6400 laptop comes with a built-in webcam at the top of the LCD screen. This camera can take still pictures and record video for use with video messaging. You can access the camera via a software program already installed on the computer. This program can be accessed right from the desktop screen.
1.Turn on your Dell Latitude and click on the "Start" tab on the main desktop screen. A list of options will appear in a drop-down window.
2.Click "Dell Webcam" from the list of options in the window.
3.Click on "Dell Webcam Center" and the program will open. A capture window will appear on screen. Beneath the capture window will be a control panel.
4.Click on the camera icon to take a still photo.
5.Click on the "Record" button to record video with the webcam.
I hope you find it helpful. Best regards.
Aug 23, 2011 | Dell Latitude E6400 Laptop Computer PC...
I want to block yahoo messenger on my computer, how can i do it?
Just block it from the Firewall settings: go to Control Panel > Windows Firewall > Exceptions and untick the mark next to it.
But the best solution is to uninstall it , from Control Panel > Programs.
Aug 13, 2011 | Computers & Internet
Is there a restore partition on a hp mini 110 laptop. If yes, how to access it ?
Using the Recovery Manager
The recovery manager helps you recover your factory shipped computer programs and drivers should you experience a computer failure or instability. The recovery manager can be accessed by either of the following:
Click Start and start typing recovery in the search field. Select Recovery Manager from the list provided.
Recovery Manager is also accessible by pressing F11 during boot and allows users to recover the factory preinstalled image.
The recover manager allows you to perform the following by selecting the Yes button and then the Next button on the appropriate screen:
Software program re-installation:
o
If you select Yes and Next , you will see a software re-installation screen that helps you reinstall software that was included with your computer. Select Next and you will be provided a list of programs and be asked to choose which program you wish to reinstall. Follow the onscreen instructions.
o
If you select No and Next , you will be asked if you want the following:
Hardware driver re-installation:
o
If you select Yes and Next , you will see a hardware driver re-installer screen that helps you reinstall hardware drivers that were shipped with your computer. Select Next and you will be provided a list of drivers and be asked to choose which driver you wish to reinstall. Follow the onscreen instructions.
o
Microsoft system restore:
o
If you select Yes and Next , the Microsoft System Restore requires you to leave the Recovery Manager and by selecting Next , you will be forwarded to the Windows System Restore program. Follow the onscreen instructions.
o
Recover your computer to its original factory condition:
o
If you select Yes and Next , your computer will automatically start the shutdown procedure and reopen in the System Restore program. Be sure you want to completely restore your computer to its initial factory settings before proceeding. Otherwise select cancel.
o
If you select No and Next , you will be provided information for contacting HP Support. Clicking Finish will close the program.
Mar 16, 2011 | Computers & Internet
How to enable internet on Dell Precision M4400
fistly confir that which antivirus u use.
if it norten, thn follow these step.
Scan for Internet-Enabled Programs and Apply Firewall Rules Using the Interface
  1. Double-click the icon in the system tray to display the Norton Internet Security window.
  2. Click to select Status & Settings and double-click Personal Firewall to display the Program Control screen.
  3. Click the Program Control tab:
    • If the Manual Program Control list is empty, click Program Scan to look for programs that use the Internet.
    • If the Manual Program Control list is not empty, click all the check boxes and press Delete and then OK.
  4. Click the Program Scan tab to display the Program Scan window.
  5. Click to check the scan boxes under choose the drivers you want to scan.
  6. Click Next to allow the Program Scan to list all the Internet-enabled programs found on your computer.
  7. Click All to select all or check the box next to each program name to select the programs that you want to create firewall rules for and click Finish.
new_note.jpg Note: All the programs that you select appear in the Program Control dialog box. In almost all cases, you do not need to modify the Internet Access or Category options. If you do need to modify these options, click the triangle to the left of the option in the Internet Access column and select the change.
  1. Click OK to return to the Norton Internet Security main window.
  2. Re-enable Norton Internet Security and launch the program that is having difficulties accessing the Internet.
  3. If the application now works with your Internet connection, you have successfully created firewall rules for the programs you selected.
    If the application is still not working with your Internet connection, proceed to Check if a rule in Norton Internet Security or Norton Personal Firewall is Blocking Internet Access
Nov 17, 2009 | Dell Precision M4400 Notebook
CD drive not recognized error code 0F00.281A
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program
Click Start, click My Computer, and then see whether the drive is listed.
Is the drive listed? loadTOCNode(2, 'moreinformation');
If the drive is listed, try to play or access a CD or DVD.
If you can play or access a CD or DVD, you are finished with this article.
If you cannot play or access a CD or DVD, you may have to reinstall some programs. Some programs might not be able to use your CD or DVD drive until you reinstall those programs. If the problem occurs again when you install or uninstall those programs, contact the manufacturer of the program to see if an update is available that solves the problem. Some examples of programs that might be affected are:
  • iTunes software by Apple
  • Nero software by Nero Inc
  • Roxio Creator software by Sonic Solutions
  • Zune software by Microsoft
After reinstalling your programs, if you can play or access a CD or DVD, you are finished with this article.
If you still cannot play or access a CD or DVD,
If the drive is not listed, remove and reinstall the existing drivers.
Nov 12, 2009 | Dell Precision T3400 375W 32bit Computer...
I need to know how to get to reduced row echelon form
The matrix cell operations (row calculations, column operation) are accessed as follows:
Press [Menu] button. Highlight [MATRIX] icon and press [EXE]. The list of matrices is diplayed. If you already created the matrix, it will be listed and you can select it (using the arrows) and press [EXE].
Three menu items are displayed:
F1:R.OP (Swap, XRw,XRw->,Rw->
F2:ROW (Del, Ins, Add)
F3: COL (Del, Ins, ADD)
Matrix Operations are accessed in RUN screen by pressing [OPTN] and selecting [F2:MAT] . Availabble options ( they are commands) are
F1: Mat displays identifier Mat on screen
F2: M->L converts a matrix to a list
F3: Det Calclates the determinant
F4: Trn Calculates the transpose of a matrix
F5: Aug Augments a matrix
F6 -> accesses additional operations
F1:Iden Create an identity matrix with specified dimensions
F2:Dim
F3: Fill
In addition to the foregoing you have the matrix operations (+, -, x, square, inverse).
However there is an additional piece of software that performs the row echelon reduction on the CFX9850GBPlus. The information is available here (page 13: program ROWREDA)
The program can be downloaded from this site.
Hope it helps.
Aug 15, 2009 | Casio FX-9750GPlus Calculator
The arrows arent working, scroll lock must be on and I cant figure out how to undo. there is no scroll lock button
GOOD NEWS!
There is a scroll lock button on your computer and this is how you get to it.
Step 1
Click the Windows Start button which is located in the lower left corner of your screen.
Step 2
Click on All Programs. You will see a list of all the programs installed on your computer.
Step 3
Select Accessories from the list of available Programs. It is usually in the upper left on the list of available programs as the list is alphabetized.
Step 4
Select Accessibility, which is a sub-program of Accessories.
Step 5
Select the On-Screen Keyboard.
Step 6
Select the Scroll-Lock by clicking on the on-screen 'key' labelled 'slk' located upper right on the on-screen keyboard between the 'psc' and the 'brk' keys.
This should get that pesky scroll lock off right away!
Sincerely, CBR2009
Jul 16, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
Installed Norton Personal Firewall and now can't access the Net
1 Start Norton Internet Security.
In the Internet pane, click Settings.
Under Smart Firewall, click Configure next to Program Control.
On the Program Rules window, in the Program column, scroll through the list until you find the executable file for the program that you are unable to use.
For example, if you are unable to use Yahoo! Messenger, scroll through the list until you find the entry for Yahoo! Messenger. The rule for Yahoo! Messenger will be listed like:
Yahoo! Messenger
C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe
5
Do one of the following:
  • If you find the entry for the executable file of the program, change the Access to Allow and go to line 15.
  • If you are unable to find the entry for the executable file, click Add and go to line 6.
6
Select the executable file that you need to configure and click Open.
7
Click Manually configure Internet access (Recommended) from the drop-down list and then click OK.
8
Click Allow or Block or Monitor depending on the rule that you want to create, and then click Next.
9
Specify the direction of traffic that you want to apply to this rule, and then click Next.
10
Specify what computer or computers are affected by this rule.
  • If you choose the default setting of "Any computer," click Next.
  • If you want to limit this rule to specific computers, select the "Only computers and sites listed below" option, click Add, and enter the information for the method that you chose (IP address, IP address range, or network address). Click OK, and then click Next.
11
Specify what protocol and ports to apply this rule to. Select the protocol that you want from the list.
  • To apply this rule to all ports (default option), select "All types of communication (all ports, local and remote)," and click Next.
  • To select specific ports to apply this rule to, select "Only the types of communication or ports listed below," click Add, and select the method by which you wish to specify your port or port list. Enter the port or port list for the method that you chose. Follow the on-screen prompts for proper formatting of your lists. Specify whether the ports entered in the prior step are local or remote by selecting the appropriate check box under Locality. Click OK and then click Next.
12
Click Next.
13
Specify a text description for this rule, and then click Next.
14
Review the information about the rule. If it is correct click Finish, and then click OK.
If it is incorrect, use the Back button to go back to a previous step and make changes.
15
Click OK.
16
Click OK.
17
Try to use the program.
Apr 14, 2009 | Symantec Norton Internet Security 2009
Washing Machines Logo
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
