Question about Frigidaire Dishwashers
Frigidaire dishwasher will not drain - Frigidaire Dishwashers
    Problem Solver:
  • 5 Answers
Check the opening where the drain hose connects to your garbage disposal. There is a plug in there to prevent leaks when no DW is installed. Remove this plug and all should be well
Posted on Jun 22, 2009
Frigidaire Dishwasher has error code i30 and drain pump still runs even with door open. Tried power cycle and comes right back on running and error code i30.
Error Problem / Condition = Clogged filters or a restricted drain line has been detected. ... If the drain line is attached to a disposer, check that the knockout plug has been removed. Frigidaire Dishwasher Error Code = i30. Error Problem / Condition = A leak or over flow of water has been detected in the bottom pan.Feb 18, 2016
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-how-t...
Text info here
Frigidaire Dishwasher has error code i30 Google Search
Jun 09, 2018 | Frigidaire Dishwashers
Water not draining fully on dishwasher.FRIGIDAIRE model GLDB653AQ1
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 15, 2011 | Frigidaire Dishwashers
I have a 8 month old Frigidaire Professional dishwasher which will not drain. What do I need todo? Email: cujobuddy12@yahoo.com
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Frigidaire Dishwashers
My Frigidaire Ultra Quiet Plus dishwasher is not draining after final rinse. What can I do?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Frigidaire Dishwashers
Frigidaire Dishwasher won't drain
Try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 15, 2009 | Frigidaire Dishwashers
My Frigidaire Dishwasher is not draining
Check the direction of the drain from the dishwasher. It should go into a slightly pointed downward "TEE".
Mar 05, 2009 | Frigidaire Dishwashers
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
Jun 18, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
181 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
