Question about Craftsman Garden
Why will the engine turn over but will not start
I have a 26hp 42" twin V lawn tractor
If it's just out of winter storage, then it may be the fuel pump is dry. I've taken the fuel line off the pumps inlet side then attached a small funnel with extra fuel line to the pump. Keep the funnel above the pump, add fuel and start the engine. Once it starts, shut it off and reattach the original fuel line. I've had to do this for the past 3 years and only have to do this the first time - after that it starts all season.
Posted on Jun 13, 2014
    Champion:
  • 279 Answers
Person has to be on the seat, battery needs a good charge, fuel has to be fresh ( less that 45 days old) oil level has to be correct. If all that is good, then check that the plugs are firing. If the plugs are good and firing it should run. If no spark you may need a "ignition control box" if your model has it. www.mowpart.com or www.sears/parts will have a parts breakdown.
Posted on Jun 03, 2014
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Posted on Dec 31, 2008
mowerman1857
  • 389 Answers
SOURCE: How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
Posted on Sep 22, 2009
  • 17 Answers
SOURCE: Craftsman 42 '' 19.5hp lawn tractor gear shift
Sounds like your drive belt may have came off or it needs to be replaced. Take the battery out from under the seat to see if belt is still around transaxle. Sometimes it will jump off when doing a lot of starting stopping
Posted on Aug 04, 2010
Testimonial: "Bang-on, Barny. Many thanks."
Why is my 2012 21hp sears 42" lawn tractor blowing smoke
If it is a V twin Kohler engine, you may have a blown head gasket. It is a common issue. Great engine but has this one issue. Kohler has a head gasket kit with improved head bolts. Torque specs are included. You will need a inch pound torque wrench and common hand tools.
Jun 14, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
Need a diagram how to put a belt on a craftmans 42 inch 19 hp twin engine
http://media.fotki.com/1_p,srbkgqfsgggdwfgxgtqsskgwtqkq,th/rrdqddwqbxbwgwtsrdbxttqfksftw/1/1303472/5961991/image7270496268268023884img-th.jpg
May 26, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lawn tractor, engine model 42A707, starter spins but won't start engine; noted starter gear on top is worn down. Need help to either replace whole starter assembly with gear or just gear?
I had this same problem with a twin cylinder B & S engine and was able to get just the gear drive replaced without replacing the whole starter. Hope this helps you
Nov 10, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Does a 19hp crasftman lawn tractor have a oil
IF IT HAS AN OIL FILTER IT WILL BE VISABLE FROM THE OUTSIDE OF THE ENGINE. IF THE ENGINE IS A SINGLE CYLINDER IT SHOULD NOT HAVE A FILTER TO THE BEST OF MY KNOLLAGE THEY PUT FILTERS ON THE TWIN CILINDERS
Sep 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What is the spark plug model number for craftsman YS4500 lawn mow
go to any auto parts store with your model info as they have a book which will tell them which spark plug is best for u.
Apr 16, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Hi
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
90 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
