Question about Canon LASER SHOT LBP-3000 Printer
How to print without dark smudge on right side?
  • 35 Answers
You can try doing maintenance on the machine with the included software that you installed when you bought your printer. Cleaning out the nozzles as well as the paper feed through the options provided should solve this problem. Hope that helps.
Posted on May 06, 2014
Scanning duplex I get a line down the righthand side of all alternate pages?
With very limited information, I suspect if you observe closely on the side that has the line printing you will find a dark smudge on the glass. If this is found you should be able to use a little rubbing alcohol on a clean cloth an remove the smudge.
Mar 28, 2016 | Fujitsu ScanSnap iX500 - document scanner
Unwanted colour lines on prints
It may be time for a new printer. Colored lines are often an indicator that the printhead is worn out. Dark smudges on the back of the print are likely just a need for cleaning the inside.
Sep 02, 2014 | DSC GESTETNER - DSc38u Color Printer
Smudge line on side of page
Smudges are most likely from the toner cartridge. If you can take your finger and run over the print and it smudges, then it is the fuser.
Aug 01, 2014 | Dell C1765nf Multifunction Color Laser...
Vertical dark/smudged line on right side of paper when printing
See its a very common issue.the right side of the drum has moisture on it.remove the toner and drum and apply a hot air blower on it for some time also clean the printer internally.reinsert the toner and drum.
check by printing few pages the smudging on the right should go within 10 to 12 pages.
if the smudging doesnot go away then its time to replace the drum to solve the issue.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 11, 2009 | Brother HL4040CN Laser Printer
Smudge mark 2-in wide down right side of each sheet of paper.
Generally speaking, any area that is darkened, is receiving less light. This can come from a lamp that is failing (similar to a fluorescent lamp used for lighting developing a dark end) or a mirror or optical lense that is contaminated with toner.
This may require some disassembly to diagnose and cure.
You may also want to visually check the fuser assembly (often accessible behind a door) to ensure there is no toner buildup on the affected side.
Mar 30, 2009 | HP LaserJet 3600n Printer
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Printing greetings cards and envelopes
At the moment it is printing both sides of Greetings cards, but this printer appears to be very sensitive with regards to placng card in the exact position in the paper tray.
Why it will not print envelopes without smudging I still don't know, so I shall just have to write address by hand after I place graphic on the envelope
This 5300 was a Christmas gift from my wife and if I could afford to change it I would. The performance is very dissapointing
Kindest Regards
David Gray
Mar 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Smudges down left side of paper
Maybe something attached (corrector fluid or adhesive)on drum (green cylinder - don't touch it!) or more probably the fixing film on the fusing unit is damaged (probably some paper clip left over input bin, or trying to remove a paper jam with some sharp-pointed thing) If you have some other printer like this around, try with another print cartridge, if error persist , the fuser film is damaged...
Sep 07, 2007 | HP LaserJet 2420 Printer
Canon LASER SHOT LBP-3000 Printer Logo
42 people viewed this question
old marine
old marine
