Question about LG WM2077CW Laundry XL Front Load Stackable Washer
MY LG MODEL F1403FDS5 IS SWITCHING OFF AFTER 6MINUTES WHEN ON 30MINUTE CYCLE BUT IF YOU SELECT RINSE AND SPIN IT FINISHES THE CYCLE.
  • 401 Answers
Check the ibnlet screens for the water valve,they may be plugged, also make sure the drain hose is above the washer so it dont siphon out as it fills
Posted on May 08, 2014
SOURCE: lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Posted on Dec 10, 2007
  • 10 Answers
SOURCE: Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Posted on Feb 12, 2008
aborcass
  • 2651 Answers
SOURCE: lg wm2785H*M clothes are not spinning dry
check your soap .you NEED to use HE( high efficency ) detergent. dont believe the saleman "just use less of your regular soap speech". immediatly swithc to HE detergent problem solved
Posted on Mar 01, 2008
IFIXALL
  • 868 Answers
SOURCE: LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
Posted on Jun 09, 2008
SOURCE: LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Posted on Sep 02, 2008
Why does my whirlpool model WTW57ESVW1 starts to rinse toward the end of the spin cycle?
The rinse is supposed to start during the spin...it's what removes most of the soap from your clothing! The spin forces the water through the clothes, flushing all but a small amount of the detergent away. The rinse cycle itself is more to remove solid debris that may have become trapped in the folds of cloth. It does so by floating and agitating the clothes.
The quick wash cycle is only for things that aren't soiled much, that you need to be done fast. It's not for everyday washing, just for things that maybe need no more than a freshening up. It makes it faster by cutting corners.
Sep 06, 2014 | Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
I have an LG front loader - model WD - 804 90TP and the machine is working but it gets down to 6 mins to run the spin cycle and then goes up to 14 mins and then back down again and carries on in that cycle...
You need to check the inlet valve for good flow of the water as a SLOW water pressure can increase the timing for rinse and spin.
Similarily the DRAIN pump/valve must be checked as if this is clogged then the drain flow will be LOW and the timing will extend for full drain. Remove and clean the drain pump and it can be the reason that the clothes are still wet.
Finally check on the controller for the proper timing of the cycle.
Tips on Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Sep 15, 2011 | LG Washing Machines
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Mar 15, 2011 | Washing Machines
The spin cycle wont start as the rinse cycle finishes i here two clicks 1 to 2secconds appart and then nothing
Not sure which model you have, but if it spins after the wash cycle, and not after the rinse cycle, it is more than likely the timer.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
The rinse and spin cycles never end
I have seen this often on another brand. Once it starts malfunctioning on the rince/spin cycle, the boars needs replacement.
Nov 13, 2009 | Fisher Paykel EcoSmart GWL15
LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Mar 29, 2008 | Washing Machines
LG WM2077CW Laundry XL Front Load Stackable Washer Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
