Question about Craftsman Garden
Why will theengine will turn over but will not start
  • 1 more comment
  • pam lansdell
    pam lansdell May 08, 2014
    thanks guys I think it's gonna be in the carb and fuel because everything else seems to be firing
  • dragonsha581
    dragonsha581 May 09, 2014
    A engine needs 3 things, Air, Fuel, and Fire. First step unplug the fuel hose from the carb and see if fuel flows out. If not check the fuel filter, hose and tank. If it does then The carb may need cleaning. Start by removing the bowl and see if there is anything at the bottom of it.
  • pam lansdell
    pam lansdell May 13, 2014
    thanks dragonsha581 I got it fixed
  • Craftsman Master
  • 4,758 Answers
Battery weak--spark plug or cable is worn--carburator dirty--no gas or bad pump--gas may be old--get a manual at the library sec629 for troublshootn
Posted on May 06, 2014
  • 2 more comments
  • pam lansdell
    pam lansdell May 06, 2014
    thank you Arnie I have changed the battery, plugs, drained the gas. Guess I'll have to tackle the carburator
  • newkens1 May 06, 2014
    Check to see if you have spark. If you do then the prblem is fuel related. Modern gasoline contains ethanol which causes problems in the carb by varnish buildup. The tiny orifices clog up and the engine cannot get fuel.
  • Arnie Burke
    Arnie Burke May 06, 2014
    gud advice for us all--someone sed it eats boat motors up
  • Arnie Burke
    Arnie Burke May 09, 2014
    ur library sec629 has many manuals on engines--cars--cycles
Whydoes theengine start then shuts off
Could be a relay, fuel pump, coil, or other component.
You'll need to find out if you are loosing fuel or spark when it stops running.
Feb 21, 2015 | 2002 Pontiac Grand Prix
Location of fuel pump relay on 2000 toyota corolla
The relay is probably working correctly. It should power the pump for about 3 seconds then stop until the computer sees oil pressure or RPM from the engine.
This is a safety to help prevent a fire in a wreck.
The relay should be in the fuse box in the engine compartment.
Aug 26, 2012 | 2000 Toyota Corolla
Blown freeze plug somewhere onthe back of theengine
FREEZE PLUGS LOCATED ON REAR OF ENGINE BLOCK.YOU HAVE TO DROP THE TRANSMISSION AND REMOVE FLY WHEEL TO GET TO FREEZE PLUGS.
Jun 20, 2011 | 1995 Chevrolet Caprice Classic
My 320i takes longer to start and the engine even sputters at first. When it finally starts, the tail pipe exhausts white smoke.. a lot of it! The emission of white smoke doesn't stop even while the engine...
Your head gasket is leaking and you'll have to take your car to your mechanic, the wihte smoke is coolant leaking into theengine cylinders, check you radiator it's problably low.
Sep 15, 2010 | 1994 BMW 3 Series
F250 HPOP NO Start
if you are talking about the injector pump it will need to be bled, loosen the fuel lines at the injectors and turn theengine over till you get fuel out of them all close them and start engine it may take a little to get it started, then loosen each injector one at a time to purge any air left in the system
Jul 30, 2010 | 2002 Ford F250 Super Duty SuperCab
MURRAY AUTOMATIC DRIVE, 42" CUT, 17HP, TWINII,MODEL 42A707,TYPE 2653E1,CODE 9710235B. Battery fully charged,starter will not turn fast enough to start engine. acts as tho there is a presure build up....
Dropped / Stuck valve?
Major Overheat?
Battery weak (understand it is fully charged... but is it delivering proper amperage under load?)
bad connections betwixt battery and solenoid, then solenoid to starter?
Weak starter motor?
Mar 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
31 cc Straight shaft/ head won't turn when connected and running
pull the shat off the engine and check the inner shaft it sounds like its stripped or the theengine side is cracked hope this helps
Oct 22, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Distributor timing set
hmm ok
this will risk serious eletric shock..
start the vehicle
slowly turn the distributor left or right until you get the neat ideling tone and little to no vibration. If you turn it one way the car speeds up
the other way it slows down.. Find a place that you are comfortable with.
BTW some vehicles have the original settings marked, look for a colord(usually red) mark on the distributor and engine just line up these two.
Jul 20, 2008 | 1995 Ford Windstar
Garden Logo
75 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
