Question about Ovens
My electric oven wont heat up
Do you think it is the thermastat Are they easy to replace and will it be expensive
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    yes they are. it isnt that bad.if you have your model number and make you can go here to identify it www.techray1.com then click on the guru guy on the left. this will open another window. on the left you can select your model and unit and part. If this helps please rank me
    Sergeant:
  • 353 Answers
Check the breaker box first, turn breaker off then on. then try oven again
check the timer, sometimes the timer gets set to delay and oven won't work
second, with oven off trace entire element with finger to see if there are any burnt spots.
if no burnt spots found, there may be a burnt wire leading to element in the wall behind
please, don't forget to rate my solution.
thanks
Posted on Jun 22, 2009
My hotpoint single oven wont heat up.the light will only go on when i turn to knob to light on..but it doesnt come on when i turn the knob for oven on and it doesnt heat up...until yesterday it was working...
Hi there If everything else is working then it's probably the heating element They are not expensive to replace and can be fixed in less than an hr Hope this helps
Sep 25, 2013 | Hotpoint SY36 Style Line Stainless Steel...
No heat in oven
check that tthe cable connection to the elements is ok and not burnt and that the power is at this terminal, if present then change the element and if absent then check and change the the thermosatrt
Jul 13, 2010 | Ovens
My oven wont heat up at all. gets no gas. the top
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Feb 05, 2010 | Frigidaire FEB27S5A Electric Single Oven
Oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Dec 18, 2008 | Whirlpool AKZ159IX Oven
Oven not heating up
Hi.
If the fan is working o/k, then in all probability the fan oven element has failed.
A common problem with fan assisted ovens.
It is a fairly easy job to replace same
Nov 13, 2008 | Baumatic B180 Electric Single Oven
Bottom Coil on Oven not Heating Up
yes it is most likely the element (coil) itself burnt out. inexpensive and easy to replace.
Jun 28, 2008 | Kenmore Ovens
Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
Bosch oven
looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
hope this helps
Jan 17, 2008 | Bosch HBL 745 Stainless Steel Electric...
Ovens Logo
97 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
