Question about Zebra 105Se Thermal Printer
How to change the printhead from 300 to 203 dpiin my 105s ?
  • smallprince Jun 23, 2009
    It's Ok , but i don't find the 200 dpi printhead, only the 203 .
    Firmware or hardware problem?
    Or all of this?
    Thanks.!!!
    Rinaldo ( Italy ).
    President:
  • 2,306 Answers
You can't change it with software, you have to order and install the 200 DPI printhead. Available from Zebra and some retailers on the internet.
Posted on Jun 22, 2009
I have a Philips 105S5 15" monitor and its OSD is
"OSD Lock" is the On Screen Display Lock, a feature designed to prevent you from accidentally changing any of the settings of the monitor. To disable the OSD lock, press and hold the menu button for 10-15 seconds.
Dec 30, 2010 | Philips Standard 105S Monitor
How to change a 105S zebra printer head? Where to adjust the ohm value?
Loosen the top screw holding printhead, it will drop down and you can remove the data and power cable. Reverse to install, but make sure the small dowel pins are seated flush in the printhead. There is no place to enter ohm value on 105SL.
Oct 19, 2009 | Zebra 105SL Label Printer
I am trying to change a 300 dpi zebra 110XiIII+ printer to 200 dpi. I have the printhead.
There is one screw in the center of the top of the printhead - where the toggles are. Unscrew, open printhead mechanism and disconnect printhead cables. Connect new printhead, ensuring that the printhead is aligned properly. There are holes on the back of the printhead that are used to align the printhead. The hinged assy has pins that go in the holes. Tighten screw. Ensure you adjust printhead resistance setting in menu. The printhead has a little label on it with a 3 digit number and an ohm symbol next to it. This is the printhead resistance setting.
Jul 08, 2009 | Zebra 110Xi III Plus Thermal Printer
Printer won't print in black
If you need to change the printheads on this printer you need to do the following:
- Open the main lid (not the scanner one)
- Check the LED Screen on the printer and you will see that it gives you the instructions to hold down the "OK" button on the printer panel for 5 seconds if you want to change the printhead... So do this... Hold the OK button.
The printer will now move the printheads into the exchange position.. Wait a few seconds for the printhead carriage to stop moving around as sometimes it can catch your fingers..then:
- Lift the blue flap (lift from the front - hinge at the back)
You should now see the printheads
- Carefully lift the little blue plastic handle for the printhead and pull this up and out to lift the printhead out that you want to change
Now for your new printhead:
- Before you install it, shake it back and forth 6 times as shown to shake up and mix the ink that's pre-filled in the cartridge.
- Pull the orange covers and plugs off/out as shown
- Carefully slot the printhead into the position vacated by the old one. You may find that you need to slot it in by angling it slightly but be patient...
Once the new printhead is in position (check the other printhead to check they're the same level ie: that the new printhead is all the way in).
- Close the blue flap back into the closed position
- Close the main lid
The printer will then begin a priming routine and after a few minutes you can start to use your printer again..
Dec 20, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Canon iP100 Portable Printer
On the front of the (printhead)cover is a "hole", with that you can lift the cover .
The printhead will move to the center and you can change a cartridge.
To change the printhead if necessary you can squeez the little gray handles next to the cartridges ( one left of the CLI-36 and one right of the PGI-35) , lift the printhead handle and the printhead can be changed.
Nov 24, 2008 | Canon iP100 Portable Printer
Samsung AF Zoom 105S
dont know same prblem
Jul 04, 2008 | Photography
Philips 104 series monitor
pls help my philiphs monitor 105s vertical probelum i need service manuval pls help
Feb 14, 2008 | Philips Standard 104S 14" cRT Monitor
Zebra 105Se Thermal Printer Logo
699 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
