Question about Toshiba Office Equipment & Supplies
E220 error toshiba - Toshiba Office Equipment & Supplies
E220 error drying
i came across a hotpoint had error E220
it turned out to be the pump housing was cracked and leeking water back to the motor windings and they had gone short
and the brushes on the drum motor were worn away
replacing the pump rear section and the brushes
and resetting the error {hold in power btn power up at the mains}
cure it
i then had to come back too it and replace a faulty 1Amp triac and its driver transistor on the machines micro/control board
because although it worked aok the triac already had been damaged
and the increase in duty etc of the new pump
tipped it over the edge
replacing these two parts cure it for good
that was over a year ago and no new problems
Jun 07, 2014 | Hotpoint Aquarius WMA52 Front Load Washer
How to solve e220 and e218
Both of those errors revolve around the laminator.
E220 is Lam2 Tag Error
E218 is Lam 2 Head Lift Error
I would recommend replacing the laminator.
Sep 19, 2013 | Office Equipment & Supplies
Canon ir600 error code E220
sira canon 600 mechan E220 has cmming turn of the power has coming solve the problam how to slove the problam slove it
Jul 17, 2012 | Canon ImageRunner IR600 Copier
Canon ir 400 error code 051
I m E220 Error how to clear the error of Ir 400
Jul 29, 2011 | Canon imageRUNNER 400S Copier
We have a copier CANON IR 400 and shows the message E220
This is the Charge Coupled Device. Its a part that would need to be replaced by a technician. There is no way to explain to you how to get to it or how you could order this part. Your local canon dealer should be able to help with this problem.
May 10, 2010 | Canon imageRUNNER 2270 Copier
E220 error
it show exposure lamp blown or bad contact, open upper cover and check for possible connection for the lamp for replace if possible.
Apr 12, 2010 | Xerox Phaser 7760/YDX Laser Printer
I have a problem with the error e 051 some body help me
000 Fuser problem E010 Main motor, motor board, clock pulse E030 Counter E050 Duplex side to side problem E051 Crossway registration E200 Scan problem E200 Scan reverse sensor or scan E202 Scan return problem E204 Document sensor, scan reverse sensor or scale E210 Lens problem E220 Lens E220 Blank lamp open or lens home problem E240 DC controller E400 Document feeder board problem or document feeder interface problem E500 Sorter E620 Editing problem
Jan 15, 2010 | Canon imageRUNNER 400S Copier
My cannon ir400 eror e220
this error is related to exposure lamp , does the the two end of the lamp is blackened. Otherwise the exposure lamp needs replacement
Jul 20, 2009 | Canon imageRUNNER 2270 Copier
Canon np1530 copier e220 error message problem, how can solve this problem?
E220 is a scanner error. means:
the exposure lamp is burnt.
try copying with the top cover open, if the lamp does npt work, exchange it.
Good Luck.
Mar 12, 2009 | Office Equipment & Supplies
47 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
