Question about Exercise & Fitness
How do I service or lubricate a healthrider RC270?
It seems to be dragging or kind of grinding when you pedal it at normal speed
3 Suggested Answers
outfield502
  • 79 Answers
SOURCE: need help belt adjustment on healthrider 550i
in the back of the treadmill you will find two screws allen, if the belt is loose, you should rotate in the direction of clockwise until a point of tension,should not be too tight because it will do is it will break
Posted on Feb 05, 2010
  • 3 Answers
SOURCE: My Healthrider 400se Treadmill slows down after 10seconds
Use only a single-outlet surge suppressor that is
UL 1449 listed as a transient voltage surge suppressor
(TVSS). The surge suppressor must have a
UL suppressed voltage rating of 400 volts or less
and a minimum surge dissipation of 450 joules.
The surge suppressor must be electrically rated
for 120 volts AC and 15 amps. There must be a
monitoring light on the surge suppressor to indicate
whether it is functioning properly. Failure to
use a properly functioning surge suppressor could
result in damage to the control system of the
treadmill. If the control system is damaged, the
walking belt may change speed or stop unexpectedly,
which may result in a fall and serious injury.
Posted on Apr 15, 2010
Grand vitara 5 speed manual stiff to change when warm
what is stiff (add a noun here)
blush.....
clutch pedal stiff
shifter lever stiff.
grinds , a bad clutch will make the lever seem stiff or will grind, if forced.
gears balk? same as stiff.
false neutrals. (slips , gear not engaging)
Nov 07, 2016 | Suzuki Grand Vitara Cars & Trucks
Hi...just put together my son's new Bike (20'' Boys' Mongoose Rebel Freestyle Bike) and I noticed that when pedaling backwards, it's not smooth, and sounds like something is rubbing or grinding (pedaling...
It sounds as though the chain is too tight. Check to see when it is "freewheeled" if the chain gets tighter. Generally this will happen because the chain ring (front sprocket) was not perfectly aligned with the "spider" (thing it bolts to). You can loosen the chain a little and see if this helps. Be careful because you don't want it so loose the it comes off while riding. What I usually do is adjust the tension of the chain with the sprocket in the tight spot. Kind of tight but without the "grinding" feeling.
Good luck.
Dec 22, 2010 | Mongoose Cycling
Jan 23, 2010 | HEALTHRIDER Pro H500i Exercise Workout...
Brakes
you may have to take the rotors back off completely and look for the baby brake shoes behind the rotors because sometimes they will hang up and give you some of the problems you are having
Dec 29, 2008 | 2001 Ford Explorer Sport
Trans clunking when slowing down
Sounds like youi may have a few serious problems going on to have that kind of back lash occuring at higher speeds. I have experiance with low spped clunks on Bronkos and your type of vech being a car dealer. One you might try for low speed clunk on take off and braking at stop likts just completeing a stop? Pull the drive shaft and lubricate the splin - two check your leaf springs for weakness and wore bushings - take a look at your shocks - three u bolts holding springs to rear axle housing may be letting the axle housing actually dip or tweak or all those thing in combination - now you may have some serious slop in the pig - transfer case may be causing that clunk - as far as high spped clunk and activity you have a serous problem and you just might drop the transferr case have an accident fliping over..............Mike South Bend Indiana don't just keep driving and making problem worst...........
Jun 23, 2008 | 1996 Ford Explorer
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
