Question about Nikon Coolpix S51c Digital Camera
How to get the the screen to show the picture.
Rear screen is bright white at all times.
How do I get the picture on my rear screen?
check the lcd ribbon connector is seated properly.
May 06, 2014 | Nikon Coolpix S51c Digital Camera
32 INCH ZENITH PICTURE IN PICTURE ABOUT 15 YEARS OLD.PICTURE DISAPPEARED AND ONLY HAVE A THIN WHITE LINE RUNNING ACROSS THE SCREEN.THE SOUND STILL WORKS FINE. IS IT WORTHWHILE GETTING IT REPAIRED ??
When CRT TV's show only a white/bright line horizonatlly It is a failure of the flyback Transformer. Not all that costly to repair. Your old TV will probably still be working when all the latest plasmas and rear projections have been laid to rest. Fancy junk TV's dont get any better programs than those old reliable ones
Please rate my help++++Thanks for using FRIXYA
Aug 04, 2010 | Televison & Video
Blothes of color in center and right side of screen. Very noticable when it's a light background.
May have burned CRT(s), (if you are not talking about convergence.) Burned CRT shows when that CRT (R,G,orB), does not show in an area of the screen where it should. Check bright white color = full R, G, and B CRT brightness. Gray = mid RGB brightness. Yellow = R+G(no B), Blue-green = B+G, no R, etc.
Apr 12, 2010 | Sony KP-53V75 53" Rear Projection...
Screen shows computer brightness indicator which does not go away
unplug open case remove little white plug from rear of switches leave it out then put case back on job done no power light or buttons but picture is fine ; )
Mar 10, 2010 | Samsung Syncmaster 17" 720N Monitor
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
My 60PP93 5217 The white is very bright and the
You can carefully remove the rear top cover ( make sure it's unplugged) and carefully wipe the dust off the projection lenses and mirror and inside screen and stay away from the electronics and capacitors.Years of dust build up can blur the picture and give it a glarey picture.
Oct 17, 2009 | Philips Magnavox 9P6034C 60" Rear...
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
On bright screens picture goes to white and shakes
Sounds like a bad crt, also has you set been used to play video games if so this could be a cause for bad crt, weaking tubes
Oct 23, 2006 | Mitsubishi WT-46807 46" Rear Projection...
Nikon Coolpix S51c Digital Camera Logo
23 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
