Question about Toro Lawn Mower With Toro Power Tools
My JS60 is also fouling plug...
Very frustrating! Just completed a full tune-up, including a new magneto. I've also noticed (more than normal?) black smoke from exhaust on initial start. Am wondering if OHV's aren't seating properly or if ring is allowing blow-by, and if this might be contributing to fouled plug.
Also, can't find any kind of fuel filter. Not even a screen inside the fuel tank. And choke seems to be OK.
    Sniper:
  • 197 Answers
The John Deere JS60 does not use any kind of fuel filter.Some of the newer ones had a thermal switch near muffler that would allow air vane to shut choke off when warm.Had a couple new out of box with choke not releasing or stuck half open.So if you have one of the newer ones your choke will not open until muffler gets hot,could be where the black smoke comes from.
Posted on Nov 14, 2009
    Problem Solver:
  • 10 Answers
Check the carb float it might be stuck or the needle might be worn
Posted on Jul 13, 2009
  • 59 Answers
Check the gape in the plug
Posted on Jun 23, 2009
Hi I just bought a inner rotor kit off eBay, I 125cc four stroke,, fitted it n couldn't get spark from it, so I left the cdi box on it n put the old,original,stater plate n magneto on,my bike goes but...
You can "read" your plug to see what your mixture is.
Too rich and the plug will foul, too lean and the plug will over-heat.
Leaking oil ring(s) and the plug will be gunked-up with burnt oil.
Suggest not deviate from the factory plug heat range.
Sep 13, 2014 | Motorcycles
Black Smoke
TOO MUCH OIL TO GAS MIX CHECK LINES AND FILTERS
Jun 28, 2013 | Motorcycles
It seems I'm getting too much gas,my plugs are fouled out. The truck runs fine for 5 min when it's cold, then it will foul out if I don't keep giving it gas.
Sounds like your actually not getting enough gas, then your fouling your plugs because something isn't firing right. When your vehicle is cold it uses more gas to run smoother, then when it warms up it is leaning the fuel out and you have to keep giving it gas because it wants to die from not getting enough fuel. Whens the last time you've done a full tune up? or timing adjustment? check easy things first like air filter, plug wires....I'm sorry but I think it's going to be something a bit more difficult, atleast first start with your air filter.
Apr 18, 2011 | 1988 Chevrolet C1500
No fire to the plug
that could be from a short in the circutry even as simple as some debri build up around the blade brake magneto ground contact point that is grounding the magneto so spark can not continue to the plug could also be a fouled spark plug or could also be the magneto condenser attached to the magneto has burnt thus looseing capability to disperse the electrical energy to the spark plug, and worse case senario is the magneto is internally damaged from use also possably the magneto's air gap to the magnets on the flywheel is to exssesive for energy production hope this helps Steve
Jul 30, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Inherited a 1170 13cd608g101 with a briggs, cuts off after 20 min
From what you describe, it sounds like perhaps your magneto is breaking down when it gets hot. To test it, you will need an inline spark tester and as soon as it dies, try to restart it with the tester in place and see if you have spark. If not, replace your magneto.
When testing your battery with the multimeter are you running it at full RPMs? It should actually be putting out about 13.5 to 14 volts at full RPMs to keep the battery charged up good especially if it has an electric blade clutch.
FYI you can go to http://manuals.mtdproducts.com and with your full model and serial number you can download some excellent information including a complete service manual. They have 9 different manual you can download and should be of great help with your tractor
Oct 05, 2009 | Cub Cadet Garden
Tractor running rough and black puffs of smoke come out exhaust pipe when you rev up engine. What should I try?
Normally black smoke indicates too much gas or too much choke. Remove and clean or replace the spark plug because it is probably fouled. Change the air filter because it is probably clogged. I am not sure how mechanically inclined you are, so if you are then it needs a tune-up. If you are not then I would take it in for a tune-up(needle valve replacement or cleaning and adjustments, float bowl cleaning, and spark plug replacement.
Aug 21, 2009 | Garden
Stalling after driving when idling
change your distrubutor cap and points..... they are probably worn if you didnt do that at the same time... your code read is too new as your truck is OBD I and make sure your distrubutor isnt wet as this will casue stalling (i just added that in assuming you washed your engine bay in your 'tune up" )
Jun 18, 2009 | 1993 Dodge Dakota
Poulan Pro 200 Leaf Blower won't start. I have installed a carb kit with no results. The spark plug was wet before the new kit---it continues to be wet. I have tried a replacement spark plug with no...
Alright, remember that 2-Stroke motors are meant to do 2 things:
Break down, then Frustrate you.
So, here we go: (Electrical)
Rotor Magnets, Magneto (ignition coil), Spark Plug Wire, Spark Plug, Spark Plug Ground (Cylinder Head).
In that order!
Check your "fire" from the Magneto:
1. Check your Kill Switch. In other words, leave everything normal, and unhook it. Did she start? Kill Switch it is! Kill Switch/Wire comes from the Magneto (single wire/ground) to the Switch itself. So check that wire AT the Magneto (Is it loose and grounding out? Is the Kill Switch grounding you out where it is, because of crud, junk, or because it is touching the block when it is not supposed to?)
2. Check your Spark Plug Wire. Easy, unook it from the plug, stick your finger in, give it a crank (non-MultiMeter way). Did you get shocked? Then it ain't your Plug Wire and Magneto!
With a Multi-/Volt Meter, simply hook her up, and check for juice WHEN you pull the rope. If you got juice, it ain't your Plug Wire or Magneto!
Checking Spark the "normal" way: Grab the Plug with a pair of insulated pliers, hold the plug end against the cylinder head, and pull your rope. Any Spark? What color?
3. STILL no fire. It leaves: Magneto and Plug Wire.
Luckily, they are both in the same place! Tear your blower down, and check to see if the Magneto has slipped out of place (gap is WAY out), or if the Plug Wire has worn to the point it is grounding you out. While you are there, check your Kill Switch wire, to see if she is grounding you out then and there.
4. STILL no fire. That means: Magneto Failing, or Magneto JUNK.
Buy another one, replace it! (Or steal one from another junk Blower/Weedeater. These things are fairly standard, and easy!)
Or, Bad Plug Wire. Meaning she has failed out on you.
Wait......that means: Replace your Magneto! Lucky the things are built together right?
Apr 22, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Toro Lawn Mower With Toro Power Tools Logo
374 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
