Question about Thermador Ovens
I have a thermador 366us1/01 When trylng to move the range out the cabinet guy pulled on the oven door. The left side popped out with the smaller portion of the hinge flopping around below the longer upper portion wbich still seems attached and ok. The smaller part is not bent nor does it have any rough edges to indicate being broken. How do I get that piece back in and working?
SOURCE: thermador professional range model prds484gg dual fuel
We just had to fix ours. There are some videos on youtube to give an overview of clip types.
On ours, we pulled the upper long hook down to the lower hook, then slid the clip lock into place. It then looks more like a one-piece hinge unit. Tip the door back into place, lift up to the horizontal metal piece, then slide the clips back to the open position(tis did take a screwdriverto push them back)-so the two pieces become two pieces-once inside the door frame again.
Posted on Jan 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
Posted on May 23, 2009
barkencoa
  • 3463 Answers
SOURCE: Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Posted on Feb 04, 2010
Testimonial: "Ideal, thanks!"
  • 1891 Answers
SOURCE: repalce a broken door hinge on upper oven
you must remove side panel . if wall oven slide out on a table strong enough to support is during service . mm
Posted on Jul 16, 2010
  • 552 Answers
SOURCE: I removed the oven door
Take the door back off and try again. The hinge is not in the receptical all the way
Posted on Apr 13, 2011
I can't open my oven
Some ovens have a latch that must be locked for self-cleaning. Look at top of oven door and see if you have a sliding latch. Try to move it back to the left to unlock.
Jun 16, 2012 | Thermador SC302T Electric Double Oven
I have the SC272TB Double Oven. The top oven is fine but the lower one will not stay closed. Whether baking or not, the door seems to pop open just enough to turn the light on. We walk by and press the...
Welcome to FixYa.
Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges.
Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
The issue with those Thermador wall oven and freestanding range doors ( especially on the freestanding "professional" line ) is the weight of the door is so great, the hinge will actually move slightly over time, other times the entire hinge will need to be replaced.
This is what I'd recommend ( also official Thermador remedy, rest assured as I am a authorized factory trained Thermador service provider ) before pronouncing the hinges need replacing though.
**This does require a somewhat involved repair, so if you don't feel completely comfortable or have any reservation to trying this, please call in an local authorized Thermador ( B/S/H/ ) service provider.**
Recommendation: Adjust the door box hinge per instructions below.
1. Pull the oven away from the wall about 12".
2. Remove the hinge box cover plates.
3. Remove the vertical side trim piece. It covers one of the screws that must be loosened.
4. Loosen the 4 screws that secure the hinge box.
5. Place a rolled up dishtowel at the bottom of the door and close the door and apply light pressure to the door while re-tightening the four screws.
See fig below
6. Re-install the hinge box covers & side trims.
7. Re-install and secure the oven.
That should do it, ( or as stated, improve the situation ) if the hinges are too far gone they will need to be replaced unfortunately.
Let me know if you require further assistance or if indeed this solved your problem.
Thank you for choosing FixYa today and good luck going forward.
Regards,
Macmarkus :)
Jan 26, 2011 | Thermador C302U Electric Double Oven
Is there any way to tighten this door up ,the one i have comes down just a little and the light comes on
Hello, Welcome to FixYa. Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges. Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
See fig below
Regards,
Macmarkus :)
Jan 06, 2011 | Thermador SEC271BS Stainless Steel Single...
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Mar 31, 2010 | Thermador C302U Electric Double Oven
How do you unlock the oven on a freestanding Accubake gas range/oven? Its a whirlpool gold.
Take a wire coathanger and cut the long wire from the middle.
Bend a small "U" shape on one end.
Slide the "U" in from the left side of the oven door near the top center.
Moving the wire back and forth slowwly to grasp the lock latch.
When you feel the latch pull the wire firmly to the left to open the door.
Then have the latch mechanism repaired.
Mar 26, 2009 | Whirlpool Ovens
Thermador Oven SEM272
I have a THERMADOR 6 burners gas unit, if the door is not completely stright, sometimes cause this kind prblems.try to move up and down several times first.
Jul 05, 2008 | Thermador Ovens
Thermador professional range model prds484gg dual fuel
Nov 04, 2007 | Thermador POD301 30" Pro Series Deluxe...
Door is locked- F53 Error
OK...you need to replace the lock, but first you need to get the darn think open. I looked at it, couldn't figure out how, and left it. My 14 yr old starting looking at it (after the kids had their TV, Ipod, etc taken away from him for the weekend.....) and he took a coat hanger from the side to pull the latch open.
The rest is straightforward sheet metal disassembly except for the front panel...label the connectors with a piece of tape before you pull the cables connecting the front panel (unless you are able to read a schematic). You can buy the part from AppliancePartsPros.com
AP2836100 (486324) Latch, door (microwave)
for about $100....next day delivery, and your ready to cook your Christmas goose!
Aug 22, 2007 | Thermador C302U Electric Double Oven
Door
your oven needs two new hinges on the affected door. I have seen this problem many times, the internal stops on the door bend over time and cause the door to not close all the way. They are fairly easy to replace, you just have to split the door open to repalce em. Hope this helps!
Dec 19, 2006 | Thermador SEC301BPSS Electric Single Oven
Ovens Logo
19 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
