Question about Sewing Machines
Huskylock 460d MOVABLE STICH ****** WHAT DO I USE THIS FOR
2 Suggested Answers
SOURCE: where can I buy blades for a huskylock 460D
check with a husqvarna dealer
Posted on Dec 10, 2012
936 Huskylock needle bar does not move up and down.
First, make sure the machine is engaged to sew. some machines,
have a knob inside the flywheel on the left side that disconnect the sewing mechanism to wind a bobbin without the needle bar moving.
Cheers,
Embroidery Services
San Diego, CA
Jun 15, 2016 | Sewing Machines
Huskylock 460d tensions are very loose what are the normal tension numbers
Tension adjustments will vary from machine to machine. The standard factory setting is the midway point between high & low number, however, that may change over time. You can always start with the standard factory setting and then tweak it to get the correct tension. In your case, you would need to tighten the tension on the threads that are loose.
FWIW--be sure that you always raise the presser foot when threading your machine. This releases the tension disks so the thread will seat properly. Also, give each thread a little tug to insure the thread is all the way in the disk. Sometimes you will hear a little pop sound.
If you are having difficulty determining which thread needs adjustment, use different color threads in each and test your machine. It will be obvious which thread tensions need adjustment. Once you determine the tension settings that work for your machine, make a note of them in your manual so next time you won't have to go through the process again.
Apr 29, 2016 | Sewing Machines
I have a Huskylock 460D and the thread keeps coming out of the lower looper. Can you help?
un thread your needles before threading the Lower looper. thread lower looper, then thread needles and your good to go
Jun 30, 2014 | Husqvarna Sewing Machines
Overlock problems
it would be a good idea to have the machine checked to see what's causing the squeeking problem and what's causing the pedal to get hot.
Dec 02, 2013 | Sewing Machines
Huskylock 936 is making an irritating chatter noise. Stitches are fine but moving by hand the wheel seems stiff. Got from dealer used and long drive away like this and not sure if it is normal. Something...
Sounds like maybe its to do with the loopers hitting in the bottom,go to the manual and make sure that you have not moved the coverstitch lever..also, do you have the right bottom plate on for the stich your trying to do?
Apr 29, 2010 | Husqvarna Huskylock Computerized 936
MY MACHINE IS GATHERING UNDERNEATH AND
the teeth of your sewing machine was lowerd thats why if you stich did'nt go forward, adjust it afward, to adjust open the plate and thight the small bolt.
Mar 31, 2010 | Husqvarna Huskylock Computerized 905
Won't form a chain stitch
You 910 serger doesn't have the option for a Chain Stitch. It is a 2, 3, or 4 thread serger. You can do a good number of different stitches but a chain stich is not one of them.
If what you mean it that it won't "chain off", meaning sew with no fabric beneath the foot as you gently pull the thread towards the rear of the machine, that could be for a number of different reasons. First, change the needles and unthread the machine and start over. If the threads are not exactly where they should be, your serger won't sew correctly. A great video on threading your machine can be seen at:http://www.husqvarnaviking.com/mediafiles/huskylock/index_en.html
Sep 12, 2009 | Husqvarna Sewing Machines
Viking Huskylock 910 Upper Looper problem...
You will find that it was most likely the top looper has moved to the left too far, undo the looper clamp and press the looper to the right by about 3mm. Then turn the machine over to see if it still hits anything, when the top looper comes up past the bottom looper there should be about 0.5mm clearance between the two. Try this first please.
Also the arm shaft may have moved. Trace the shaft back to where there is a clamp type crank with usually a hexagon head clamp screw. Loosen this and set the top looper so as the eye of it is just past the needle when it is all the way up and to the left.
You are correct in not using the machine under power, turn by hand when you think it is correct and make sure there is nothing hitting.
Jul 06, 2009 | Husqvarna Huskylock Computerized 910
Need to find compatible presser feet for Huskylock 700
Sorry, not familiar with the Huskylock 700. Suggest you visit authorized husqvarna viking dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 28, 2009 | Husqvarna Huskylock Computerized 905
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
