Question about Home
I have an igloo kool mate 36 my power cords are good and fan runs .But it will not get cool i have no idea what could be wrong with it does any one elese
My e mail is smellybelly447@gmail.com the cooler has no compressor or freeon electric flows though a certain meatal and causes cold or heat and fan circulates it should be simple tech thank you tim thomas
  • 333 Answers
SOURCE: Kool Mate 40 Cord melt down
The unit itself is the problem. You should call coleman customer service and tell them you have been haveing this problem from the start and ask to talk to a manager. Tell them that the cord has been replaced numerous and that you checkd voltage and this is fine. You want a new unit because it has been happening since you bought it and all the keep sending is the cord. Tell them if anythig bad happens pertaining to safety issues that you don,t want to call the better bussiness office and that they will be responsible for any damage done due to a faulty unit. Be professional about it and I am sure they will help you.
Posted on Jan 08, 2009
SOURCE: The 5640 Coleman cooler motor runs, but unit does not cool.
This is a thermoelectric (TE) cooler. There is no gas' to replace in it's cooling system. It is possible the thermoelectric coupler has gone bad. Unfortunately Coleman does not seem to offer a replacement part. If you Google thermoelectric couplers, maybe you can find something on the web. Good Luck.
Posted on Jun 08, 2009
  • 3 Answers
SOURCE: fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Posted on Jun 13, 2009
  • 4 Answers
SOURCE: Coleman 12-volt cooler stoped working/fan burned out
Sound like you have the newer version. These fans can be found at Radio Shack or anywhere computer parts are sold. It doesnt have to be an exact replacement. Just big enough to fit over the Cooling fins. Also make sure it's a 12 volt motor
Posted on Jul 14, 2009
rohntech
  • 422 Answers
SOURCE: My coleman electric cooler model
For that to happen the electronic component that causes to cool the container already defective. It need to be replace with similar parts.
You can fix it, if you have some knowledge in electronic or electrical, know how to test of component parts, able to use test instruments.
If you don't have such knowledge, call a service technician to do that.
Good luck.
Posted on Jun 26, 2011
Igloo fr1082
Sounds like an airflow problem. No air going into ref section. Usually a defrost problem and the coil is ice up in freezer section preventing airflow.
Aug 13, 2014 | Refrigerators
Fridge noise cutting out
To be honest it sounds to me like your fridge may be ok?
To extract the heat from within the fridge interior a compressor (motorised pump) moves gas around a series of pipes around the cabinets insides. This movement of gas causes heat to be picked up and taken away externally to the outside world. When the fridge temperature reaches a predetermined level (around 5C) the compressor shuts down and all is quite. The sound of running water you hear is the coolant gas changing state from gas to liquid and running through the coolant pipes. If the fridge is doing it's job and keeping the content cool then I wouldn't worry. One of the reasons you are probably noticing this sound is because it is a table top fridge. Built in fridges make the same noises but you don't really hear them so much because of the cupboards screening the sound.
Dec 27, 2013 | Igloo Cooler IGLOO Freezer. 3.6 cu. ft....
Igloo kool mate 36 heats but does not cool
I have been looking for <a href="http://www.coolmyhome.com">home heating and cooling in Phoenix</a> and they might be able to fix your problem.
Aug 29, 2013 | Heating & Cooling
My portable igloo icemaker is not making ice
i had the no ice making issue , it was running water in the tray but not enough to make the ice. I call service for the machine it self and they told me to . 1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hour but I only did it for 1 hour. when I plugged it back in and started it. It is now making ice.
Mar 05, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
I need a replacement condenser fan for model# EQK 1350 part #F12021 any idea where I can find one?
I was looking for the same condenser fan blade, for my emerson quite kool 1100. F12021-02 can be found on ebay for 24.95 + 15.00 shipping hope this helps, and good luck......
Jul 10, 2011 | Emerson Quiet Kool 10MW42K Air Conditioner
Jan 08, 2009 | Coleman (100076) Compact Refrigerator
I HAVE A 91 HONDA ACCORD WHICH HAS TWO ELEC FANS
Both fans cool the motor. If you have the air conditioner on both fans will run because the cars cooling system will have to disapate more heat. If you have the air conditioner off only one fan will run because the heat load on the engine isn't as great.
Jan 01, 2009 | 1991 Honda Accord
ACER 3680 will not power up
hello, am temab concerniong your problem on powering your system right?
I hope the best thing for you to do is by checking whether the processor cooling fan is running cause that causes the system not to power on or power on and before short seconds it flickers and go on off again . there is nothing wrong with your power jack. If the problem is that the pc fan is not rolling then change the fan but if the fan is roling then change the processor itself. any other question?
Aug 25, 2008 | Acer Aspire 3680 Laptop
Home Logo
143 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
