Question about Toshiba e-Studio 232 Black and White Copier
Clean Unit -Image
Transfer Seperation unit -Image
I have a problem with a bizhub C203 what can i do?
Verify the problem is in the imaging units or the transfer belt units.Remove the transfer unit and clean on vacuum cleaner the transfer belt cleaning blade.If you see the stripes on transfer belt after cleaning is work normally.If not observ stripes on transfer belt the problem is located in imaging unit.Enter in service mode :Press Utility key-Meter count- Details-Stop 00-Stop01 Select Test mode-select Gradation test pattern and select the Cyan press Start,after select Magenta Press Start,Yellow +Start,Black4+Start.If any color test pattern is not graduate the problem located to image unit when is not graduaTE.
Jul 28, 2014 | Konica Minolta bizhub Office Equipment &...
Yellow background how can solve
Replace the image unit yellow with OEM you do not clean image units replace them. then next is the transfer belt
May 31, 2014 | Konica Minolta bizhub C450P Laser Printer
The machine status of my konica minolta is p21, what does this mean?
P 21 Color shift test pattern failure.Relevant electrical parts is the image transfer belt unit.
Wipe clean the surface of the transfer belt with a soft cloth if it is dirty.Change the image transfer belt unit if the transfer belt is damaged.Clean the 2 sensors located upper side of unit.
Apr 18, 2013 | Konica Minolta Office Equipment & Supplies
Ineo +200 status p 6 and p 21
P-6 : Cyan imaging unit failure
P - 7:Magenta imaging failure
P -8 :Yellow imaging unit failure
P -9:Black imaging unit failure
Select Imaging Process adjustment - D Max Density and if the setting value is negative readjust.
Check the drive transmission portion of the imaging unit and correct as necessary,clean theIDC registration sensor windows if dirty,clean the contact of the imaging unit connector if dirty,check the high voltage connector for proper connection.If necessary change the image unit or the image transfer belt unit.
P -21 : Color shift test pattern failure.
Wipe clean the surface of the transfer belt with a soft cloth or change the image transfer belt unit if the transfer belt is damaged.
Feb 21, 2013 | Konica Minolta Office Equipment & Supplies
P-27
P - 26 1st image transfer ATVC black failure
P - 27 2nd image transfer ATVC failure
P - 29 1 st image transfer ATVC colour failure
Check the transfer belt unit contact and that of high voltage board for connection and clean or correct the contact.
Change the image transfer belt unit.
Clean the sensor windows on the transfer belt unit.
Feb 10, 2013 | Konica Minolta bizhub C450P Laser Printer
The prints have/Lines streaks in the image on all colors what needs to be replaced?
Enter in the service mode and tested in part every colors.Press Utility key - Meter count - Details - Stop 0 0 Stop 0 1 select test pattern gradation test select the colors and press Start key(the test is make A3 paper).If the test is OK verify the transfer belt unit and the transfer roller unit.If the lines appaire on the surface the transfer belt clean the belt cleaning blade and the cleaning brush used a vacuum cleaner.Clean used a special long tools under every image unit LED lines.
Feb 01, 2013 | Minolta C250 Color Copier
What is error p-21 of konica minolta bizhub c250?
P-21: Color regist test pattern failure
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
P-21 error of c250
4 Change PRCB.
E065 canon NP 6030
If I rember correctly, Your transfer roller unit is arching out. I would first clean off the loose toner in the unit & from the seperation unit. You will need to remove the transfer roller unit. If that dos not clear the code you will need to replace the transfer roller unit. Good Luck
Mar 10, 2011 | Canon NP 6035 Copier
I have a minolta CS pro and got a C0210 code. Please give answer in layman's terms please.
Hello this is going to be an issue with corona wires it could be the charge corna unit or the transfer seperation unit check the corna wires and springs that hold the corona wires in place if corona wire is bad replace also check for arching on the ends of the corona asseblys you can normally smell the arching or you can just replace the charge unit for the drum unit and the transfer seperation unit as well
Feb 03, 2011 | Minolta EP4000/5000 CS/PRO Copier
Toshiba e-Studio 232 Black and White Copier Logo
12 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
