Question about Xerox WorkCentre 4150 Black and White Copier
Change the toner cartridge for ar m420u - Xerox WorkCentre 4150 Black and White Copier
Hi i refil the toner for my sharp ar-m207 and later the copier say add toner can not print or copy help my please
You have to replace the whole toner cartridge because there is a crum chip on the back of the toner cartridge. When the cartridge reaches empty and the copier says change toner the copier burns that chip so it can not be reused again.
Aug 24, 2011 | Sharp AR-M207 All-In-One Laser Printer
After installation my sharp ar-m420u copier mx-2300g displays error codes L1-00 and F2-00
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
Jan 11, 2011 | Sharp AR-5320 Black and White Copier
ERROR CODE F2 00
improper cartridge (destination error,life cycle error
Jun 08, 2010 | Sharp AR-5320 Black and White Copier
My copier sharp AR-161 is not working it's write
please change toner cartridge chip your toner cartridg is fail due to toner empty
May 12, 2010 | Sharp AR-160 Copier
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
Feb 10, 2010 | Sharp AR-M237 Digital Copier
Sharp AR-C240P Printer Prints Everything with red cast
iF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Jun 23, 2009 | Sharp AR-C240P Printer
Xerox WorkCentre 4150 Black and White Copier Logo
43 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
