Question about Mitsubishi VS-6047 60" Rear Projection Television
Why does my tv powers up with setup wizard
I was working on convergence in service mode. I decided to reset the red and blue. I'm not saying it's the cause, but I've been working on the tv for weeks, I was working n the convergence settings. For days now, everytime I turn on the tv, it automatically starts with setup procedures. I turn on the tv as normal, not service menu, and it automatically asks me to choose english, french, or some other language. I g thr the setup procedure. Everything is fine. I power it off and turn it back again, and the setup starts again. Sounds like a setting, how can I fix it?
techman
  • 3130 Answers
SOURCE: Convergence problem w/ red horizontal only-WS-65807
Do not try to adjust anything yet!! Adjustments do not get out of alighnment all of a suddenly. The convergence adjustments are there to do minor aging alighnments. I would first check for bad solder connections on the convergence IC's first.
Posted on Sep 09, 2007
ginko
  • 19396 Answers
SOURCE: WD 62627
This guy had a problem similar to yours
http://www.fixya.com/support/t387173-toshiba_57hx94_reception_problem still unsolved. It seems to be a software problem, I will try to get more information
Posted on Mar 01, 2008
  • 31 Answers
SOURCE: Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
Posted on Apr 24, 2008
  • 3 Answers
SOURCE: Component Video Problem--Again
Had to get my chassis replaced for similar reasons. it was still under warranty so i lucked out. however i was out of a tv for 3 months off and on because of all the troubleshooting that had to be done before Mitsu said replace the chassis
Posted on Apr 29, 2008
Neiday
SOURCE: Timer light won't stop flashing, no powers since setting timer
DM BOARD replace entire board (New $707.25 Used: $325-561.25
Replacing few capacitor will be temporary fix, at best.
Advise: Please get 3-4 yeras of warranty on such a big-ticket item
Posted on Feb 11, 2009
I have sony tv kp-65wv600. It has problems. color and video is blurry, double vision, letters are curved
You have a convergence failure.
Convergence IC failure is very common. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless
Feb 24, 2011 | Televison & Video
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
The picture is producing a double image which appears to be in red only with a slight bending of the images on some parts of the screen.
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Note if one STK chip fails, you replace both regardless.
Feb 20, 2011 | Panasonic PT-47WX49 47" Rear Projection...
The picture is warped red & blues distorted
Try This:
Note if one STK chip fails, you replace both regardless. They will be right next to each other.
Feb 20, 2011 | Toshiba 57H81 57" Rear Projection...
I have what appears to be shadowing of the words.. and picture.. blue wave across the top of picture..
Your Convergence ICs are likely failing. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Feb 20, 2011 | Hitachi 57SWX20B 57" Rear Projection...
At times the screen becomes double
When you say "double" do you mean you see the colors somewhat seperated or see maybe blue or red outlines around objects? Does the screen distort?
If so then:
Your Convergence ICs are likely failing or it is a bad solder joint related to that area. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Note if one STK chip fails, you replace both regardless. There may only be one STK chip in this set. If there are two, they will be right next to each other.
Feb 20, 2011 | Mitsubishi WS-55857 55" Rear Projection...
My 65 inch sony tv half the screen is having colors like 3 d
Try This:
Feb 20, 2011 | Sony KP-51HW40 51" Rear Projection...
Picture is no longer working properly. Picture is blurry and colors are all wrong. Ghost image. Happened all at once not gradually. What needs fixed mitsubishi 65" medallion series. appox 7 yrs old
Try This:
Feb 19, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Adjust color convergence automaticly
I hate to tell you but if the colors are not aligning the way they used to is because the set has developed a problem know as a convergence problem,you should be able to align the colors (red,Blue)but if they are not going in is because the covergence IC's are going bad,If you are familiar with electronic service you can do some of the work yourself but sometimes still does require the help of a servicer to do the aligments from the inside,if you are not too familiar be safe and call for assistance.
Oct 20, 2006 | Zenith R56W28 56" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
