Question about Emerson MW8107WA Microwave Oven
Remove 4 pin bulb - Emerson MW8107WA Microwave Oven
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
TYPE BULB FOR PANASONIC NNP295 COOKTOP LIGHT
Halogen Cooktop/Night Light Replacement
Be careful as the Cooktop Light Cover and the bulb may be
hot.
1. Unplug microwave oven or disconnect power.
2. Loosen the screw to open the Cooktop Light Cover.
(Be careful not to lose the screw.)
3. Replace the old bulb with a new one.
(use Max. 125 V, 30 W, Wide Pin Capsule Type/GY8.0~9.0
recommended)
do not touch a new Halogen bulb with bare hands.
Fingerprints may result in shorter life. Remove fingerprints
with alcohol.
If this bulb is not available locally, contact your local
Panasonic dealer. Part number is F612E6Z00AP.
4. Reinstall the Cooktop Light Cover with a screw
Dec 02, 2014 | Panasonic Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
GE JVM1640WB004 light bulbs break off when trying to replace them
GE uses a bulb that includes two flat pins. It looks like a bulb and removable socket, but it isn't. Just a way to cost you more. The bulb is removable from the top where it's mounted, and removed from the hole that it sticks vertically down thru. 1. You have to remove the unit cover to get to the bulb. 2. You have to unplug the connector to remove the bulb. 3. You have to squeeze two plastic pins, to extract the bulb from its location. This is not a common bulb; good luck finding one.
Nov 14, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
We have a Jenn Air Microwave Over our built in oven. The light is burned out. How do we replace it? it is a jmc 7010ADB. Thank you Jan G
Mine is JMV8166BAS over-the-range model, and yours may be similar. Disconnect electric source (pull plug, or turn off circuit breaker).
1. Locate and remove 2 Phillips head screws on top projecting from cabinet/wall,etc,
2. Carefully & slowly, slide entire front vent 1/4" towards your left simultaneously pulling toward you.
3. Remove vent filter, if any.
4. In very center maybe beneath filter space, locate approx.4" width aluminum colored metal cover, possibly held in place with Phillips head screw.
5. Remove screw, exposing small light bulb.
6. Gently pull back on bulb, replace with identical wattage, 120V bulb from big box or appliance store.
7. Human touch may shorten life of bulb, so carefully push wire prongs into plastic bulb inlet socket using whatever allows you to grip bulb in the limited space.
8. Reverse 5 - 1 for reassembly. Before replacing vent assembly, notice the small notched angle clips on the bottom before aligning to microwave unit, as these were slightly tricky on my unit when inserting & sliding assembly 1/4" toright.
Jun 30, 2010 | Microwave Ovens
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the internal light bulb in the sears elite microwave convection oven
Hi there, I'm just running out the door, but came across your question after checking my solutions, and thought I'd give you a quick run through on where most lights bulbs on microwaves are usually located. One, they're either on the outer left side of the microwave (look for 4 phillip head screws within a cover approx. 3''wide x 4" long). If not there, then it's located on the top of the oven. Remember, before you remove anything...first, remove the plug from the wall outlet (receptacle) Again, you'll be removing 4 phillip head screws. Then, after removing the top cover (sometimes, you'll have to slide one way or the other, then lift) look again for the 4 phillip head screws within a cover approx. 3" W x 4" L. Remove this cover, unscrew bulb, and then replace with the same bulb. Its best to remove the bulb first, then take it with you to your nearest appliance store. This will help make it easier for the clerk helping you. Then, after you replace and secure all your covers and screws, and are completely done...you can plug your oven back into the wall outlet.  Then turn it on to check and see if your lights back on and in operating order. I wish you the best of luck, and if you have any more questions regarding this matter, feel free to contact me again. Jim
May 21, 2010 | Kenmore 80412 Microwave Oven
HOW DO YOU REPLACE THE LIGHT BULB IN A GE 1540 MICROWAVE?
1) unplug unit and remove microwave cover (phillips on 3 sides)
2) unscrew white funnel shaped plastic part near back of control panel
3) remove specialty bulb and disconnect leads
4) look for T170 bulb replacement (eBay has them) or roll your own 25W bulb solution
Nov 11, 2009 | GE JE1540 Microwave Oven
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
Amana AM6177 Microwave
Interior light bulb is located behind the grill, above door. It requires removing 3 or 4 screws to remove grill. I have same problem. I pulled out bulb, it looks like it was glued in some type of foam material. There are two pin connectors at the mounting. but I can't see how they fit into bulb.
Apr 07, 2008 | Amana AMV6177 Convection/Microwave Oven
Emerson MW8107WA Microwave Oven Logo
11 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
