Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Bad LCD = Bad PC Board unfortunately...
I have the exact same problem. My RP2100 was installed in 2002 and the LCD display got worse every year until now, with nothing being displayed. All the research I've done says that there is no way around it - you have to buy a new PC Board: part# 010253F. You can get them on some web sites for about $300 and try installing yourself. I've talked to a qualified RP service person that gave me an installed price over double that, so I think I'm going to try to install on my own.
    Top Expert:
  • Raypak Master
  • 8,861 Answers
Check grounds to board also check transformer for voltage look for blown fuses
Posted on May 19, 2016
3 Suggested Answers
kapishtech
  • 2272 Answers
SOURCE: I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 10, 2010
adamh294
  • 310 Answers
SOURCE: Since we had the RP2100 installed two years ago,
Were the ignitor and the board replaced because of this problem and its still happening? If so, it is probable an incorrect gas supply. If you know the gas supply is adequate, then power is not getting to the ignitor or power is not being distributed from the board. As you stated they are new, it gets alittle more indepth. If there is an incorect gas supply or if the refractory kit is flaking (finding white stuff on the burner tray) then you are probably getting an incorrect burn which will melt through the ignitor wires over and over againm until either venting or gas supply is fixed. If you have a flex line as your gas supply that could be the issue. If the venting is not correct this could also cause this.
Posted on Oct 27, 2010
Lcd monitor clicking
Hello
According to your detailed description, there are two chanses for this fault. Either its LCD panel of backlight inverter baord has some kind of short circuit. Detailed troubleshooting should be done. It is a highly skilled work. OK.
Feb 07, 2012 | Computers & Internet
Since we had the RP2100 installed two years ago, we have had problems getting the unit to light. I went through the manual and did the procedure for lighting, but nothing happens and there is no clicking...
Oct 15, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a 2 year old toshiba 42lx177 and I just noticed a vertical line of very small lighted dots running up the center of the screen. You can just make it out while watching a program but it is readily...
Its a failing LCD driver, not a lot you can do about it unfortunately, eventually it will get worse. Usually lines or dots are a bad driver board, but sometimes its also a bad flex cable on the LCD. Being 2 years old you probably don't have warranty, but if you do have extended warranty file a claim now, its only going to get worse, and there is no quick or easy fix.
Jan 02, 2018 | Toshiba 42LX177 42 in. LCD HDTV
When i turn on the tv i only get a picture on 1/2 of the television. the other half is distorted and has rotating lines. sometimes the clear picture is on 3/4 of the screen and only 1/4 of the screen is...
There is a high probability this is the tcon board, located at the back of the LCD controller.
I'll need the exact TV model number in order to be able to tell you what exactly the board number is.
It is not guaranteed - it may be the main board or, even worse, the LCD itself; not many people know, but the LCD dispay has quite some electronics literally inside it or glued to it in a totally unserviceable way.
If that electroncis burns out , the whole LCD goes to trash even if it's physically intact.
It's unfortunate, but not uncommon.
Still in your case replacing the tcon board is the first thing I'd try.
Ah, one more thing - sometims the cables that connect the tcon board to the LCD also burn and cause similar troubles. When replacing the tcon board that will become apparent.
Please rate this answer if it helps.
Nov 10, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Display is flickering and goes out and the screen become black. I attempted to hook up external display and get the same results. I think the issue may be a bad inverter card? System has winXP Home...
try tapping the LCD bezel, if you sense that the LCD would flicker, your hunch might be correct about the bad inverter card. it would also depend if the LCD type has an inverter. or worse case scenario - LCD is already failing...
Hope it helps!
Oct 26, 2009 | Gateway MX3215 Notebook
How to reset a RP2100 pool heater with original pc board
up and down button and mode or enter at same time for 7 seconds
Sep 08, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak RP2100 pool heater set temperature stuck on 50 degrees
Could be spider webs in the orfices, which would allow the burners not to light.
Could also be a bad thermostat or pressure switch.
Jun 19, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Hard to read lcd on controler
Please read the problem "Bad LCD = Bad PC Board...", which I meant to post as a reply to this problem...
Jun 11, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
420 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
