Question about Linksys Wireless-G WRT54G Router
Attempting to connect new AT&T Tilt phone to router causes internet crash
I have had my Dell laptop connected to my Linksys router wirelessly for years, while my Dell desktop is connect through a cable. I just bought a new AT&T mobile phone (Tilt) which has wi-fi...every time I try to connect the the Tilt via wi-fi is shuts down my internect connection on everything and I have to reboot my cable model, wireless router and computer...any ideas?
  • 143 Answers
Re: Attempting to connect new AT&T Tilt phone to router...
Well... That's an interesting problem.
Try changing the wireless channel that your router is running on via the web interface in the router. See what happens when you try to connect the "Tilt" then.
If that doesn't work, then find out if the Tilt is running on 802.11b or 802.11g. Disconnect all wireless devices from the router and change the router's Wireless standard to either B or G ONLY. (Whichever the phone is.) Connect the Tilt again without any other devices connected to the router. See if it reboots again.
Those are basics for now. I've never tried connecting a phone to a router like that before. Otherwise I would definitely contact your provider and ask them about it. Given that the WRT54G is the most common consumer-level NAT router on the market, they are sure to be having issues with it where other customers are concerned.
Unless another wireless device you have is causing the issue. But that is what you are trying to pinpoint with the above procedures.
Give it a go and see what happens.
Posted on Nov 04, 2007
0 characters
3 Points
No internet access
please upgrade the firmware version
Jun 21, 2010 | Linksys Wireless-G WRT54G Router
I bought new laptop Dell vostro, it is not able to
Probably your network is secured so you will need to configure connection (provide WEP or WPA passkey to connect).
Double click on wireless network name you wish to connect and put encryption key
Nov 26, 2009 | Linksys Wireless-G Broadband Router
Wireless Router Causes XP PRO to Crash. I just purchase a Linksys WRT110 wireless router and installed it using the EasyLink setup cd. The install went OK but Windows XP PRO immediately crashed and...
Have you unisntalled all the Linksys sofftware through add/remove software. I had a similar problem with an IOGEAR Bluetooth transceiver, I did the setup from the CD, my laptop (Dell C640) blue screened each time. I uninstalled all the IOGEAR software and my laptop stopped blue screening. I never installed the software for a wireless router, I always use the WEB interface and my life is my simplier.
Jun 02, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Mar 11, 2009 | Linksys WRT160N Wireless Router
New WRT54GS Router, Wired Desktop not working
To do this you would restor it back to factory which means old you programs and documents that have been added will be permatly lost inless you put these files on a usb flash brive or burn them to a cd.
Jan 04, 2009 | Linksys Wireless-G WRT54GS Router...
Cannot detect the router
What version of the router do you have 1,0 or 1,1? This is located on the bottom of your router. There is a firmware update for both models, I will provide link. Also how is your laptop connected wired or wireless? Let me know and I will try to help you troubleshoot your problem. We always can set up your router manually.
Jan 10, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-G WRT54G Router Logo
259 people viewed this question
Top Linksys Routers Experts
 C. Dante
C. Dante
Are you a Linksys Router Expert? Answer questions, earn points and help others
