Fax error code ng 202 epson
Hi have an epson wf3640 faxes out fine, but when trying to receive a fax it says eroor ng202
  • 24 Answers
SOURCE: Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
Posted on Sep 25, 2007
Ajkill
  • 2035 Answers
SOURCE: Hi, Remote Fax Error being displayed
As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX mode.
Press Select.
Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
Change the setting from Yes to No using the + (right arrow) button.
Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
Press Select.
Press Options 10 times until MAX SEND SPEED appears on the LCD display.
Change it to 9600 BPS using the - (left arrow) button.
Press Select.
Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
Press Select.
Press Options 11 times until ERROR CORRECTION appears on the LCD display.
Change the setting from On to Off using the + (right arrow) button.
Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes. The X6100 Series only supports 1-D MH encoding with the error correction. Fax transmissions without ECM and other ECM types can result in bad quality on the received page.
Posted on Mar 11, 2008
SOURCE: HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters Information It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured. From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
  3. Enter the parameter ____ on the key board and press the Check Mark.
    • 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    The screen will read Cfg param val: 26
  4. Enter in the value ____ and then press the Check Mark .
    • 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    Screen will read Test -001+
  5. Press the Reset button until you get back to Ready *
Posted on Oct 13, 2008
  • 111 Answers
SOURCE: FAX errors 345 346 and 350
HP.com has a web page for your product with all of the fax error codes listed and how to interpret them:
Fax Error Codes
Once the page opens, you'll have to scroll down until you find your error codes in the list. The codes in that section of the page don't seem to line up well. All of the codes have to do with the quality of service on the phone line. If the people you're faxing to are receiving all of their faxes except from you, I'd suspect your phone line may have a problem. Here's what I got from the list:
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Check with your phone company to see if their are any problems on your line. It looks like anything that even momentarily interrupts your phone connection will cause these errors. Good luck.
Posted on Nov 04, 2008
SOURCE: Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Posted on Jun 02, 2009
Erase fax memory on epson workforce 3620
If you see an error message telling you that the product's fax memory is full, try these solutions:
  • If you set the product to save received faxes in the product's memory or inbox, delete any faxes you have already read.
  • If you set the product to save received faxes on a computer, turn on the selected computer. Once the faxes are saved on the computer, they are deleted from the product's memory.
  • If you set the product to save received faxes on a memory device, connect the selected memory device containing the save fax folder to the product. Once the faxes are saved on the memory device, they are deleted from the product's memory. Note:Make sure the memory device has enough available memory and is not write protected.
  • If the memory is full, try sending a monochrome fax using theDirect Sendfeature or sending your faxes in smaller batches.
  • If the product cannot print a received fax due to a product error, such as a paper jam, the memory full error may appear. Clear any product errors, then ask the sender to resend the fax.
May 24, 2017 | Epson Office Equipment & Supplies
Unable to send faxes Error code NG #018 appears
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Mar 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
NG result
NG is just the error and not the problem, you have to read the code with the NG, it could be a phone line problem, a problem with the fax on the other end, a busy or not answered fax...any number of problems.
Oct 09, 2009 | Canon LaserCLASS Fax 710 Printer
Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Jun 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
WHAT IS ERROR #202 MEANS
hello! i just checked the dervice manual for the rror202 that you said that you are having did not find that code could you clarify thanks brother sr tech
Jan 22, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Error code 634 on Panafax UF-770
The receiving fax machine is turned off or not functioning. Try calling your cell phone.
Do you have a DSL phone line?
Nov 21, 2008 | Office Equipment & Supplies
Need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Sep 03, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
NG: POOR LINE CONDITION / OUT OF MEMORY
You can adjust the Compatibility mode. This adjusts the sensitivity of the machine to interference on the phone line by lowering the transmission speed:
a. Press Menu, 2 (Fax), 0 (Miscellaneous), 1 (Compatibility)
b. Press Up or Down arrow to select "Basic"
c. Press OK.
d. Press Stop/Exit.
e. Try resending the fax.
If the problem continues we recommend you try the unit on another line at the current location or another location. Always restart your machines after you made changes, that way you will see the results.
Feb 26, 2008 | Brother IntelliFAX 5750e Laser Fax
Open Questions:
1,096 people viewed this question
k24674
jasbo
jasbo
