Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Reset brew light on but wont brew
How do I fix a Keurig V1255 with a flashing LCD display?
Keurig Platinum Reset for the Not Ready Light - YouTube
? 1:21
https://www.youtube.com/watch?v=xjWIQpttTc8
Jun 22, 2010 - Uploaded by Lsailor1
This is a reset method for using on the Keurig Platinum B77 coffee ... Show more ... set to brew in morning ...Missing: v1255
Fix Keurig Vue V700 Not Brew
Nov 14, 2015 | Vue V1255 Professional Brewing System...
All lights are blinking on coffee maker & unable to brew.
The cups only brew one mug at a time. Open and close the lid to check if that resets itself.
Otherwise, turn the machine off and on again to "reset" the function. Also check that there is enough water
Nov 12, 2013 | Keurig Coffee Makers & Espresso Machines
After brewing a cup, lights are flashing and it needs to be unplugged to reset to brew
It's time to descale your brewer. Run a full reservoir of pure white vinegar through, and then a full reservoir of water, "brewing" and dumping one cup at a time. You might have to do two reservoirs of vinegar if you've never rescaled it before.
May 23, 2012 | Keurig Elite B40 Coffee Maker
Motor stuck in brew postion wont reset even with the brew group out
Hi
Leave the brew unit out but put everything else back in and then turn the machine on. the brew drive should reset to where it should be so you can put the brew unit back in, but make sure that the brew unit is ready to install.
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. If you have you key you can insert it in the front of the brew unit. There is a round hold in the center below the "Push", and twist it clockwise until it stops and the 2 marks are lined up. If you don't have your key you can do this. Push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Press the "Push" lever until you hear a click and you are now ready to reinsert the brew group in to the machine.
Dec 31, 2010 | Saeco Incanto Classic Espresso Machine
Keurig Special Edition that will not brew
all the lights are blinking its clean, descaled, filled with water and the power button and all the buttons just blink and it wont brew just had this machine less than 6 months and the machine will only quit blinking when i unplug it and yes ive tried different outlets when i plug it back in all the lights start blinking again and it wont brew i want a solution to this problem and i dont want to be sent to another site where they charge me to answer a question the $119 i payed for the thing should be enough im ready to throw it out the window im so frustrated with it
Mar 17, 2010 | Keurig Special Edition B60 Coffee Maker
Wont brew.. I get just a very short burst then
plugged needle holes especialy the top one , clean with toothpick or paper clip
Feb 18, 2010 | Keurig Platinum B70 Coffee Maker
The brew group does not seem to engage properly. All the lights work, along with steam and water out of the wand. The red light flashes and switches between red and cup back and forth. It does start the...
Hi
Check behind the drip tray for coffee grounds. Make sure that your drip tray is locked in. If its not fully locked it, this could be your problem. If everything is removed but the brew unit, grab the handle without pushing the press button, and pull. If the brew unit comes out, it wasn't locked in. Put the drip tray in. Set the brew unit on the drip tray. Now slide the brew unit towards the machine with a little force and see if that locked it in?
Jan 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Brew cup stuck unable to get out
If you open the door and take a flashlight, light in the front/middle of the brewing unit. You will see a little screw, take a screwdriver and loosen it, bend little on the little plastic above where the screw was and pull out the brewing unit.
When you have the brewing unit out then you need to reset the machine and brewing unit.
To reset the machine you have to turn off your machine, open the door.
Look in the down left corner, you will see a hole, look in the middle of the machin you see another hole and in the upper right corner.
put a screwdriver or similarly in the left corner and in the middle of the machine, turn on the machine and put another screwdriver in the upper right corner. hold it in place to the machine not get any noise more.
To reset the brewing unit, first put the plastic back again (that one you loosen with the screw first).
If you look back on the backsida of the brewing unit, in the middle you will see a plastic that looks lika a handle, force it down and you will see all the other parts will move around little. Turn it to you can see the little mark on the front goes to the N mark.
Best regards
/Mirran
Jan 29, 2009 | Saeco Vienna De Luxe Espresso Machine
Brew unit
Make sure you have brewing unit in start positions, if you have a press on your brewing unit make sure to press it to you hear a tick, then you can fit it in the machine.
Mar 02, 2008 | Saeco 762111651808 Espresso Machine
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
42 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Jim London
Jim London
jmt
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
