Question about Acer Computers & Internet
Acer TM6460-6752 Travelmate reverts back to it's manufactured birthday time and date when powered down for a couple days? How do I get it to stay current?
    Sergeant:
  • 293 Answers
Sounds like your internal battery is bad open up and remove battery and check with volt meter for correct voltage if it does not have correct voltage replace
Posted on May 07, 2014
SOURCE: acer 5630
it may need a new bios battery
Posted on Nov 13, 2007
SOURCE: Acer Travelmate 8210 touchpad problem
My 8210 has given me endless trouble and I just cut my finger trying to open it up!
In addition to the touchpad problem, mine has a serious issue with overheating and a strange problem where the screen flashes black intermittently for no apparent reason.
Posted on Aug 01, 2008
slfowler29
  • 51 Answers
SOURCE: acer travelmate 613txv beeps 5 times then shuts down
Try removing and re-installing the memory.
Posted on Mar 24, 2009
Geekman
  • 32281 Answers
SOURCE: laptop will not keep current date/time
The BIOS battery is nearly flat and this is causing the time to drift.
Replace the BIOS battery with a new one, then you will need go into the BIOS configuration to set the date and time.
Posted on Apr 30, 2009
benwabnick
  • 2404 Answers
SOURCE: Inspiron laptop clock incorrect
Go into the BIOS by turning on the laptop and pressing F2. In there i believe on the main screen you can change the time and date. Do that, save changes and exit and then go into windows and see if it keeps the right time and date.
Let me know how it goes.
Posted on May 12, 2009
TM 6460-6752 Series loses its time and date when shut down
The coin cell battery on the motherboard is depleted. Get the number off it and get another one to replace it . You may have to go into the bios if it won't boot correctly to input the correct time and date.
May 06, 2014 | Computers & Internet
Hotkey problems
Try going back in time to when you knew it worked. Click the windows key, type restore point in the search box. Wait for it to load and select a suitable date.
Dec 26, 2013 | Acer TravelMate Computers & Internet
Every time i turn my laptop on the time and date keep changing and going back nearly 3 years,i have been told it is the CMOS battery is this right?
What you have been told is correct. When the real time clock battery (CMOS) runs out then the date and time will revert back to the day the bios was programed, in your case 3 years ago.
You can set the date and time while you are using Windows but each time you power the laptop down it will loose this information.
A quick workaround is not to power the laptop off but put it to sleep instead until you have got a CMOS battery for the laptop.
Regards.
Aug 15, 2010 | Computers & Internet
Date has reverted back to2006
Press Menu and select the Setting Menu. Navigate down to "Date Adjust" and press Right-arrow, and the Date Adjust screen will appear. Navigate around and change the settings. Press OK when done.
If you've misplaced your manual, you can download one from the manufacturer's web site at http://www.pentaximaging.com
Feb 03, 2010 | Pentax Optio M20 Digital Camera
My Acer extensa4420-5963 has been acting funky for the last three/four days. Started out my date and time went haywire. Clock kept losing time as soon as laptop was turned off and reverted to battery. Then...
First of all the RTC (real time clock, BIOS/CMOS) battery has run out. This means the computer cannot keep the date and time when its turned off and disconnected from the mains. You will need to take the laptop to a reputable PC repair store and have them fit you a new CMOS battery.
As for the power on problem, this well could relate to the CMOS battery being drained but also could be a number of different reasons why it won't power on properly.
In my experience laptops that have problems powering on is either to do with the DC adapter on the laptop that has a dry solder point or the power board is failing.
Either way i would take the computer to be looked at.
Regards.
Jan 25, 2010 | Acer Computers & Internet
When switching on it goes back to the original date & time
Your cmos battery is flat, that must be an older laptop.
Requires a strip down to the mobo to replace battery.
This will require a Tech to do so.
Dec 22, 2009 | Acer TravelMate 242LC Notebook
System restore stopped working
try doing error disk checking (checkdisk) it will tell if the restore files are corrupted, since you mentioned it shuts down on restoration.
or try restoring to another date.
Dec 29, 2008 | Acer TravelMate 4200 Notebook
Acer Travelmate 4670 Power Button LED
Check your power settings:
Start
Control Panel
Performace Information and Tools
Adjust power settings (in left hand collumn)
Whatever is indicated with a bullet in front of it - click "Change plan settings"
Then choose "Change advanced power settings"
Make sure your Power Button is not set to hibernate instead of shut down.
Good Luck.
Apr 06, 2008 | Computers & Internet
Acer Travelmate 2410 - problem turning on
first remove ram sticks use eraser to clean its pins re insert it or if you have two sticks installed then use either stick and check. you can send reply parmanand1984@gmail.com
Sep 20, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
