Question about GE Dishwashers
What to do with a GE GLD4500N10BB Dishwasher panel not working
I Have a GE GLD4500N10BB Dishwasher that the button panel seems to be unresponsive. If i unplug for 30 sec and replug the lights come on for Normal and Heat Dry pads but then shut off a few sec later. Sometime it will have a random beep. Any Suggestions.
johnychel
  • 796 Answers
SOURCE: dishwasher not running
hello sir.....
is the Start/Resume indicator flashing?
Opening the door or interrupting the power stopped the cycle. Close the door and press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
may be the motor has stopped due to an overload....as you have mentioned...many of the buttons were pressed...
The motor automatically resets itself within a few minutes. If it does not restart, call for service.
In Canada, call 1-800-807-6777, or your nearest designated
service center.
In USA ..Call the Whirlpool Customer eXperience Center
toll free: 1-800-253-1301.
If you need further assistance, you can write to us with any
questions or concerns at:
Customer Interaction Centre
Whirlpool Canada LP
1901 Minnesota Court
Mississauga, Ontario L5N 3A7
Posted on Feb 25, 2008
  • 111 Answers
SOURCE: Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Posted on Dec 18, 2008
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
SOURCE: jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Posted on May 19, 2009
  • 127 Answers
SOURCE: kenmore dishwasher ultra was quiet guard 3 model
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
Whirlpool Dishwasher will not start
Contact appliance repairman,
sounds like either a control problem, or the is a problem with the solenoid that opens up to let water in the dishwasher at initial start.
Jul 09, 2013 | Dishwashers
Model KUDS30FXSS1 Kitchenaid dishwasher control panel stopped working at the end of a cycle.
I had a similar problem: unresponsive buttons, then the 1 hour wash button led was on but the other buttons weren't working at all.
I power off for more than 30 seconds and after that everything return to normal.
Thank you for the hint!
Nov 03, 2012 | KitchenAid Dishwashers
Installed a new control board in GE dishwasher: GLD6860NSS. Still having problems!
check the board for a dry joint where wires are soldered to it. I researched this problem before. It was where one board was wired to another. Bad joint was not supplying enough power.
Mar 23, 2017 | GE GLD6860NSS Stainless Steel Dishwasher
GE dishwasher with tactile board. Worked fine until special fingers caused issue? Now only the CANCEL and timer light-up when CANCEL pressed. Pump runs to drain for 2 minutes. Stops. NOTHING. Dont see...
This should help: PDW8000 series: press the resetbutton once. This will cancel the washing cycle and pump the water out of themachine. PDW9000 series: open the door aninch and wait for the machine to stop. Touch the reset button to cancel thewashing cycle and reboot the panel.
According to the GE Owner's Manual for the PDW9000 series only: If the"start/reset" light is flashing, close the door until the water pumpsout (this takes approximately 2 minutes) and the light stops flashing. When thelight stops flashing, the dishwasher can be reprogrammed and restarted. If the machine is unresponsive, killthe power to the machine by turning it off on the wall switch (if applicable)or turning the circuit breaker off. Leave the power off for 30 seconds,then turn the power back on. If thatdoes not work here is the repair info: Get into the service mode by pressingkeypads #8 and #4 for 3 seconds. Then reset from service mode. LINK to SCHEMATIC
Mar 28, 2011 | Dishwashers
Control panel inoperable - 2nd time this has happened. First time repairman said "it was fried" because the panel is just under the countertop - of course this is how it is designed to be. Now it has...
Is it operable when the door is close? I'm having a similar problem. The console panel on the top of the door appears to be not working. No lights. No buttons will respond. However when the door is shut, I can squeeze a finger to the start button and actually start the dishwasher. Light also come on when the dishwasher door is closed.
Aug 11, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
I am looking for a stainless panel to insert in my dishwasher, model #GLD4500N10BB
You can find many different stainless steel (as well ascolors, designs, seasonal, etc...) at www.applianceart.com. They have stainless metal and faux stainless that was featured on HGTV and the Today Show.
Oct 31, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Model GHDA480N00WW non-responsive
Im having the same problem with mine.. Did you find a solution
Jun 23, 2009 | General Electric GHDA480N Built-in...
Fails to start Midea dishwasher WQP12-9240AS
Thankyou Loopyloolisa! you just helped me fix my unresponsive midea dishwasher! Great help
Jan 17, 2009 | Hotpoint 24 in. HDA3400G Built-in...
GE Max dishwasher no lights on panel
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
Feb 04, 2008 | Dishwashers
Dishwashers Logo
62 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
