Question about Samsung RS2534 Side by Side Refrigerator
Samsung refrigerator rs-25h5111bc error code
The LED readout on my new refrigerator says FF. The freezer side shows the temperature, but the refrigerator side says FF. I can't find anywhere what FF actually means for this particular refrigerator. Neither side is cold now and the compressor is not turning on. Can anyone tell me what FF actually means? I am more than frustrated as I have had this unit for 10 days and can't find any information, even on the Samsung site, to give me any good information. It has been working fine until today and we have done nothing different.
  • Jill H
    Jill H May 06, 2014
    Apparently the new panel readout "FF" is the demo mode. The previous readout was OF. We were able to reset it and it is now cooling. So if anyone has the reading FF on the new model Samsung refrigerators (2014), it likely means you are in demo mode. Thanks for letting me post my question here anyway. I think we are set now.
catriver
  • 878 Answers
SOURCE: samsung rs2578ww
littlern, Im thnking the 61 was your ambient temp on the refer side. The codes show up differnt than that. This is a very complicated machine. Sounds like a temp sensor has gone bad, the main board or the compressor overload itself. You can put it into a self diag mode by pressing power freeze and power cool together for 8 seconds. This is going to test all the sensors, fans, defrost cycles. The error that comes up will show as a - or | running clockwise on a digital 8 figure and then has to be decoded on a chart. For exampe: If the - is present on the bottom side of the 8 in the display, this means a a number 4 error which means a rerigerator fan error. It's gets pretty confusing, it's good you called the service tech. Make sure to get an extended warranty on this model..Catriver..post back.
Posted on Oct 02, 2006
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Posted on Jul 02, 2008
SOURCE: Samsung double door refrigerator/freezer is not
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Posted on Jun 21, 2009
  • 3 Answers
SOURCE: error codes for Samsung Fridge
does anyone know what error code 3 is? Have the same problem, wont cool on fridge side freezer side is fine...
Posted on Mar 01, 2010
SOURCE: samsung rsg257 showing "of" on
I had this same problem. Per the manual, it's been changed to "store display mode". To cancel this mode, press the Power Freeze and Freezer buttons at the same time for 3 seconds until a "Ding-dong" sound is heard and the unit will cool. I tried it and it worked!
Posted on Dec 19, 2010
What does FF mean on the display, it won't change the temperature
FF is usually a Freezer Fan error code. A qualified service tech needs to look at the unit, checking for iced over fan motor, loose plug connection, ect. Pleazer Appliance...
Sep 23, 2014 | LG LFX25971ST Bottom Freezer French Door...
Flashing freezer led
a flashing display is how samsung shows error codes. try and draw a picture of which segments of the display is flashing. think of the figure 8 and then try to show which part of the 8 is being shown. that is how we can tell what error code needs fixed.
Nov 02, 2013 | Samsung RS2630SH Side by Side Refrigerator
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
Refrigerator displaying error "ER FF".
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Cheats sf
We don't understand what you exactly mean. If it means a eror code, please find below the error codes and its solutions.
Er CO - Communications Error Er-Ff- Freezer fan fault. Write again if you're not satisfied with this answer.Thanks.
Feb 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an LG SXS side by side refrigerator that will not dispense water. The display shows FR & FF. If the supply is switched off and then back on again the display resets for a period of time. Over...
Er FF - Freezer Fan Error - This can be caused byfrost accumulationon or around the freezer fan. Unplug the unit for 3-4 hoursto allowthis to melt off. If error code persists, call Customer Service.
Jan 20, 2011 | LG LSC26905TT Side by Side Refrigerator
I have an LG LRSC26923TT Refrigerator. The display shows "Er" in the freezer temp area and "FF" in the refrigerator temp area. Nothing happens when I press any of the buttons. However, the refrigerator...
ER FF is a freezer fan error. Basically the mainboard is not receiving a feedback signal from the freezer fan motor within 65 seconds. When this happens the error code will come up and then none of the buttons will work.
You can clear out the error code by unplugging and plugging the machine back in. The error code will come back if the problem persists. Check around the freezer fan motor fan blades to see if ice buildup is interfering with the operation. Clearing out this ice may fix the issue.
If the problem comes back, then the fan motor may be getting ready to go out or the unit may not be defrosting properly.
Hope this helps, please rate my solution.
Jan 09, 2009 | LG LRSC-26922 Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
29 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
