Question about Frigidaire ATF6000ES Front Load Washer
Atf6000fs1.. how do I find and clean out the lint trap so I can change my detergent and get this machine to stop stinking!
    Problem Solver:
  • 14 Answers
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it, or if the vent itself has finger holes or something that you can grab and pull or slide it open.
In some front loading models the two vents are at the back and both look like nonremovable vents. If that's the case, one actually pulls right out easily. It might then have two parts (the grate on the dryer side and the screen on the exhaust side) that snap or slide apart, with a space between for collecting lint. If that's the case, and you haven't cleared it in a long time, it will be packed full of lint. The two parts snap or slide apart, then you can get at the lint and remove it. Then snap or slide it back together and just push it back securely in place in the dryer.
Posted on Aug 09, 2010
  • RCarrier Aug 09, 2010
    The above pertains to a dryer. For general advice on cleaning a washer lint filter, tryhttp://www.ehow.com/how_2083872_clean-wa...
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
How do you service the lint trap on FRIGIDAIRE FRONT LOAD washer MODEL ATF6000FS1?
What are meaning by service? You can clean it out and even clean out the coin trap of the unit for regular maintenance.
Aug 09, 2012 | Frigidaire ATF6000ES Front Load Washer
After every wash the lent stays on the clothes
here are a few suggestions Two things that come to mind...1) Your wash time is too long. Unlike front loaders, top loaders clean quickly. No need to use the longest wash setting unless the item is really dirty.
2) You are overloading the machine. Items should move freely and circulate from top-to-bottom several times during the wash.
3) try using more detergent, One of the things good detergent does is keep lint (and dirt) suspended in the water and off your clothes. 4)http://www.ehow.com/how_2083872_clean-washing-machine-lint-trap.html
check that link for lint traps in washers
Jul 21, 2011 | Washing Machines
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Water leakage after cleaning lint trap
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
Apr 07, 2010 | Miele W1926A Front Load Washer
There are streaks (lint?) left on clothes after
It is not on the machine, it is on the detergent that you are using and the amount of water for per grams of detergent, maybe you are putting to much detergent, try to lessen the detergent and more water instead.
Nov 06, 2009 | Kenmore Washing Machines
Dryer shuts off on E-1 code..Lint trap has been cleaned as well as vent hose and vent riser to outside.
Check for brisk air flow at outlet of vent hose (hose disconnected). If weak, remove lint screen and retry. If now has brisk flow, clean screen in hot water and detergent.
Aug 01, 2009 | Dryers
It STINKS and MOLDS!!!
There is nothing you can do about this, for this is a design flaw. You can however get an LG replacement for such models at any washer spares store, but make sure it is the new design which does not trap muck.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 04, 2009 | LG WM-1832C Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
448 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
