Question about HEWLETT-PACKARD HP G62 Notebook
How to recover HP laptop from usb or recovery partition when winload.exe not found?
HP Windows 7 recovery media on usb would not boot. I used easyBCD to make it bootable and got a message that \windows\system32\boot\winload.exe not found. I put a copy in all drives in windows\system32\boot\, message remains the same. I tried all options in easyBCD booting from recovery partition then usb. Changed active partition from recovery to system, then rebuild bcd. No change. any ideas on how to beat this?
    Habit-Forming:
    New Friend:
  • 82 Answers
Don`t loose time.
back up your files....
format and install windows from a disk!
Posted on Apr 10, 2015
3 Suggested Answers
  • 202 Answers
SOURCE: recovery manager does not detect recovery partition
THERE IS A WAY if your recovery partition is not damage
goto mange by right click on my computer
click on disk manager
right click on d: make it active
and restart your computer.
if partiotion has no errors like missing files or bad sectors
your recovery goes on fine.
Posted on Feb 04, 2012
SOURCE: how do I recover from usb or recovery partitoin when winload.exe not found
First change your RAM and again try recovery
Posted on May 06, 2014
Edit windows boot options for:Windows Setup. No partition
I think you can access this by going to "Start", "run", thentyping "msconfig". This will bring up the config menu where you can change boot options.
Mar 16, 2016 | Dell Inspiron N5010
Hp omni will not boot past starting windows
windows is corrupted, (guess at huge virus attacks.)
needs fresh load from HP recover CD, lost those,?
if the fresh load fails then the HDD is bad.
i can see you tried safe mode
but fails.
an all in one, quasi desktop, not a true desktop at all.
its like large notebook with legs.
and as such more hard to repair, (parts non standard)
looks like its a 2012 product from HP,
so is supported until 2022.
i guess the F11 key recovery failed.
so page 13 in the book on this PC tells you
how to make recovery media
ah but only works on a running system(must be done day one new pc, so you have this recovery DVD-r or USB stick.
quote
Recovery media can be created on either blank DVD
discs or a USB flash drive (one or the other, but
not both). Create recovery media from the recovery image stored on your hard disk drive.
This image
contains the operating system and software program files that were originally installed on your computer at the factory. You can
create only one set of recovery media for your computer, and the
media can be used only with this computer. Store the recovery media in a safe place.
end qoute.
(wow only one set allowed)
if the hdd is corrupted, even the restore partition can be a wreck.
only real media is good, DVD or USB.
http://h10032.www1.hp.com/ctg/Manual/c03255541
you can also , do it the hard way
call hp and beg for media
or use free micro soft down load ISO, for w7/8 or 10
and install the MS software
then use the COA sticker on back of PC for the lic. activaiton.
W7 in this case.
then down load all hp drivers for w7 and intall them.
there did all 3 ways for you.
Mar 08, 2017 | HP Omni 120-1125 20" All-in-One Desktop PC
Acer: No boot recovery to factory defaults
jake howe many discs do you have 1 or 2 ? have you ever seen windows welcomescreen ? if 2 discs windows is on one of them.
changed anything in BIOS if set optimal defaults BIOS can change
disc at start from.tap onF8,F10 OR DEL to get there one tap a second,then there find harddiscdevices and change disc.
Apr 09, 2013 | Acer Aspire Computers & Internet
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
Jan 16, 2013 | Acer Aspire 5610-4648 Notebook
I have an hp dv9925nr laptop running vista home premium 64. I tried to reset to factory settings and now when I try to start up I get a boot manager error. It says \boot\bcd status 0xc000000f error...
Most of the boot up of problem because of hardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (not from PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file. Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer and press "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority and press Enter. Please choose 1st Boot Device to USB, and then press F10 to save setting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fix it.If not,reinstall it.If you have no backups for all your data,you can use Tenorshare to retrieve data under any boot up problem.You can get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Here is tutorial to guide you how to do --How to Recover Data from Computer Won't Boot Up?-Windows Data Recovery.
Sep 19, 2011 | HP Pavilion dv9925nr Notebook
OXCOOOOOOF I was doing disk partition
Grab a copy of :
EasyBCD is NeoSmart Technologies' multiple award-winning answer to taking control of your bootloader. EasyBCD extends and revamps the Windows Vista/Windows 7 BCD bootloader, and with EasyBCD, almost anything is possible. Setting up and configuring a dual-boot between Windows 7, Windows Vista, older versions of Windows such as XP & 2003, Linux, Ubuntu, BSD, and Mac OS X is a breeze. You just point & click and EasyBCD does the rest.
EasyBCD is geared for users of all kinds. Whether you just want to add an entry to your old XP partition or want to create a duplicate for testing purposes; if you're interested in debugging the Windows Kernel or septuple-booting your seven test operating systems, EasyBCD is the key.
  • Boot into XP/Vista/7/Ubuntu/OS X and more!
and if :
Your "BOOT" folder has been deleted, was not created, or has been corrupted; and the Vista bootloader will not show.
Solution Boot into a working copy of Windows and install/run EasyBCD.
Go to the "BCD Backup/Repair" page:
Select "Re-create/repair boot files" then "Perform Action" to begin recovery. EasyBCD will recreate (if possible) your boot files and re-configure your bootloader from scratch.
If EasyBCD fails, that means a process has locked your BOOT folder. Manually delete this folder with a Live CD, recovery console, or other method, then try Type Three again.
Dec 11, 2010 | Toshiba Satellite P205-S6287 Notebook PC
How do you restore it
All HP's and Compaqs (as far as I know) come pre-installed with a recovery partition. This replaces the functionality of a recovery CD or DVD, only without the hassle of losing or scratching a recovery CD or DVD. There is one drawback to this method; namely that if the hard drive (or more likely for you) solid state drive gets damaged or erased, you run the risk of also erasing this recovery partition. If this happens, you will need to go to HP's website to order a recovery USB key. Information for ordering a recovery key can be found here. Keep in mind you can only order one recovery key per system, so if you do have to take this route, be sure to create another using the information at the bottom of this post.
  • Press the Power button to start the PC, and then press the f11 key when the standard BIOS prompts are displayed on the black screen.
    NOTE: Pressing the f11 key during startup on a computer with an HP factory image will start the system recovery process even if the prompt is not displayed.
    • If the HP Recovery Manager can access the recovery partition on the hard drive, a prompt to backup the user files before beginning the recovery is displayed. Follow any on-screen instructions.
    • If the HP Recovery Manager cannot access the hard drive to fix any system errors, you will need to use the personalized recovery disc that you created to recover the hard drive to its original condition.
    • If you have not created the personalized recovery disc, or the discs are corrupted, you can order a replacement recovery disc from HP.
  • If prompted to use the Microsoft System Restore program, click No , and then click Next .
  • When prompted, if you want to backup your personal files and settings, select the Back up your files first (recommended) option, and then click Next . Follow the on-screen instructions.
  • When prompted to Recover without backing up your files , please STOP before clicking Next . WARNING: This is the final opportunity to change your mind about recovering the PC and deleting all the files and programs. Once you click Next , the restore process cannot be stopped.
  • If you are satisfied that you want to begin the recover process, click Next . The PC immediately begins formatting the hard drive and destroying all data.
  • The recovery process may take up to several hours and will return the PC to its original condition. Any custom settings, drivers, software programs and updates, and/or hardware updates are lost and must be reinstalled.
    Once this process is complete, you can create a recovery USB drive using the procedures outlined below:
    There are three options for recovering these mini notebook PCs to their original operating system image.
    • Option 1 - Use the Recovery Manager program on the recovery partition on PC. For Windows 7, turn on the power switch, press Esc key at boot followed by F11 key for the recovery menu. For XP, press F6 key for Roxio BackOnTrack utility.
    • Option 2 - Create a personal set of recovery media. For Windows 7 and XP use the HP Recovery Manager to create a recovery image on either a DVD or an 8 GB USB flash drive). For XP, use Roxio BackOn Track to create a recovery image.
    • Option 3 - One-time purchase of the Recovery USB recovery key.
    The USB Recovery key can be purchased from the HP web site. The USB key is larger than normal thumb drive. HP can ship only one USB recovery key per unit.
    Nov 25, 2010 | HP Mini 210-1030NR Netbook
    Windows vista ultimate will not boot up
    Press enter and submit the changes :) computer should repair itself from a back up file and start as normal.
    Regards
    Jun 08, 2009 | Acer Aspire 3680 Laptop
    Can't boot and get winload.exe and ntkrnlpa.exe errors
    If you reinstall windows just make sure you do it on the partition it was already installed. If it was not installed in D as long as you do not delete or format that partition you will not lose that data or the partition.
    As for your errors you will need to reinstall windows if you cannot repair the already installed partition.
    Feb 06, 2009 | Acer Aspire 9300 Notebook
    HEWLETT-PACKARD HP G62 Notebook Logo
    93 people viewed this question
    Top HEWLETT-PACKARD Computers & Internet Experts
    Michael Vincent Cruz
    Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
