Question about Freezers
How to troubleshoot sears coldspot freezer 106 724240?
Need a repair manual for sears coldspot chest freezer model #198715610. Need to repair compressor.
Have you checked the relay or capacitor also. Generally, they need to be checked as well. You can that manual from sears or from their website. I am assuming you know how to replace the compressor and know how to deal with the gases. This could be more than you bargained for if you aren't . I know , I made that huge mistake thinking I was able when I really didn't know much about the gases like I thought I knew. Good luck.
Feb 13, 2013 | Freezers
I need to replace the thermostat on my very old Kenmore Coldspot Upright Freezer, model 106628420. I have no owners manual and there is not one to be found. I would like any help possible. Thank you so...
Not that this diagram is a lot of help, but I did find this on a Sears website:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Freezer-Parts/Model-106628420/0582/0142000?sid=PDVertical
Nov 10, 2010 | Kenmore Freezers
Have Coldspot Chest Freezer. Small size How do I set it to a colder setting?
The freezer is pre-set. There is no adjustment.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2010 | Freezers
After freezer was moved not getting cold
Unplug the unit and leave it undisturbed for 24 hours. Plug the unit back in again and see if it will come to temp.
Jun 02, 2009 | Freezers
Sears ColdSpot model number 106 7649314
REplace the fan. The fan is most likely bent and will continue to have problems until it is replaced. You can get it at repairclinic.com
May 30, 2009 | Freezers
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
95 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
