Question about Princeton Digital VL1716 17" LCD Monitor
What adapter can i use - Princeton Digital VL1716 17" LCD Monitor
My battery won't charge why not
If it's connected properly, that sounds like a dead battery. Try wrapping it in something waterproof and freezing it overnight. If that doesn't work, replace it.
Apr 06, 2011 | Toshiba Satellite A135-S4527 Notebook
The power of my Linksys Wireless-G Game Adapter [ WGA54G ], isn;t coming on! I was wondering if there is a switch to turn it on!
With Linksys game adapter there's no power switch on it when you plug it to a power outlet if adapter is working the light should come on.
You can follow these troubleshooting to determine if adapter is really bad or something else.
Make sure that the power adapter that you are using came with the wireless gaming adapter.
Power adapter is connected properly to the back of the adapter and the electrical outlet.
Electrical outlet is preferably a surge protector.
Try another electrical outlet.
Unplug and replug the power adapter.
Hold the reset button for a minute, while the adapter is connected to the electrical outlet.
If there is still no power light then it is possible that the adapter is defective, and have it replace if still under warranty.
Oct 07, 2010 | Linksys Wireless-G Game Adapter [ WGA54G ]...
How to install wireless adapter?
Hello faiz
you can download driver for your adapter from here
Click here to Download
actually this device is plug and play hardware but if you still having problem to install this adapter download driver for your adapter then install run the setup.exe file then plug your adapter when prompt
Regards
Manish
Apr 08, 2010 | HP bt450 Bluetooth Wireless Adapter
CANNOT INSTALL WIRELESS G NOTEBOOK ADAPTER
- check if the adapter met the system requirements - uninstall any previous wireless adapters installed in the computer
- insert the adapter - wait if the adapter gets detected - if it's detected it'll ask for the setup CD. - run through the recommended option first and if it fails choose the advanced option - manually browse for the drivers that your system requires using the CD - if it still fails, try downloading the most recent the drivers for the adapter - if it fails again, try installing the adapter to a different computer. - if the adapter still won't work with the other computer its defective
Mar 11, 2010 | Linksys (WPC54GS) 802.11g/b Wireless...
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN XP
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 09, 2009 | Dell 1450 (D1450U) Wireless Adapter
The adapter to my Western Digital Book does not respond
The monitor requires a adapter with a current output of 4 amps. but the Western Digital Book adapter can only supply 2 amps (half the current required by the monitor).
This means using the WD adapter on the monitor will stress this adapter beyond its capacity and continual use of this adapter on the monitor will cause it to fail and/or switch off if it has overload protection.
If you are having problems with the 2 amp adapter on the WD Book, then the power adapter could be faulty or it maybe OK when the adapter cools down.
I suggest you get a 12 volt 4 or more amps adapter for the monitor.
You may need an adapter for the WB book too if the adapter is faulty.
Dec 06, 2009 | Western Digital My Book Essential Edition...
Xbox 360 Does not recongize my wireless adapter
My adapter light is a solid red. When I plug in an ethernet cord, that'll connect.. but when I take the ethernet cable out, the 360 always reports Disconnected under Network Adapter even though the wireless adapter is plugged in.
Apr 03, 2009 | Microsoft Wireless Network Adapter Xbox...
My linksys wireless-g gaming adapter won't turn on.
Take note of the following:
- Make sure that the power adapter that you are using came with the wireless gaming adapter.
- Power adapter is connected properly to the back of the adapter and the electrical outlet.
- Electrical outlet is preferably a surge protector.
- Try another electrical outlet.
- Unplug and replug the power adapter.
- Hold the reset button for a minute, while the adapter is connected to the electrical outlet.
- If there is still no power light then it is possible that the adapter is defective.
Dec 20, 2008 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Can i install adapter to a macbook
You cannot install this adapter on your Macbook , it is only made to work with Windows operating system from windows 98se up to windows Vista, you can try to look for a airport adapter that will surely work with your Macbook...You can check this link for the complete details about this adapter http://cnet.nytimes.com/adapters-nics/netgear-wg111-usb-adapter/4507-3380_7-30791890.html
Hope that helps..............
Oct 03, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Princeton Digital VL1716 17" LCD Monitor Logo
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Fishlung
Level 1 Expert
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
