Question about Vehicle Parts & Accessories
My astroflex j5f tx2000 remote starter work only for unlock/lock button. When i press the starter button it will start but it will not continue. Whats the problem with that?
  • jricardocerv May 08, 2014
    Hi Jose magpantay, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    First is the starter making noise? And what kind of car is it? Also do you use a chip key in that car?
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
SOURCE: remote starter does not work but will unlock and lock doors.
I have a 2003 sierra and my remote starter would not work, it would lock and unlock only, checked out this site found the solution, tried it and in two seconds i solved the problem, Just press the lock button and the start button and viola it works again, thanks for all your help , GGGreat site glad i found it John
Posted on Jan 11, 2009
ltfrc
  • 227 Answers
SOURCE: how do auto remote car starters work?
Usually the car start system has a "Valet" switch hidden somewhere under the dash or in the glove box. This is used to disarm the system for when the vehicle is serviced. You will have to locate and turn the switch on, some units have a small push button. In either case it is a good dea to locate it for future use.
Posted on Feb 08, 2009
  • 131 Answers
SOURCE: remote starter will not restart my vehicle
If you have an alarm, or remote start with an alarm, you need to press and hold thethe valet button which would be hidden under the dash on the driver side, as you are turning the key sometimes remote starts have a starter disable or an alarm option to reset it that is what needs to be done, some systems even if you dont have an alarm go into a valet mode if your remote battery is old or you never reset it or the alarm kicked in or what have you. if this does not work for you then you will need to bring it to a dealership and have them do a total reset to the computer you can also try disconnecting the negative battery cable, but do this with the door open cause it will reset everything, and google the reset procedure for the key fob (remote).. do that reset for the remote and it should save you money from having to bring it to a shop or dealer.
hope this helps.
Posted on Apr 16, 2009
SOURCE: i have a astroflex electronics car starter...model
I actually found my manual!
Posted on Dec 15, 2009
My j5f-tx2000 Astro start remote turns the car over but won't start I have a 2004 Grand Prix.
i am sure that service and repair manual will help you to solve the problem easily and you can get the manual from the given link http://toolsnyou.com/
May 23, 2018 | Cars & Trucks
Why would my Aerostart j5f-tx2000 remote key fob not transmitting
I would suspect it needs the power cell in the key fob replaced.
It may have enough electricity left to work the little LED indicator but not enough to transmit. If this is the fob you use most of the time it would make since that the battery would be depleted before the other just because of the higher use.
Replacing the battery cell in the fob is what I would try first.
Sep 04, 2016 | 1995 GMC Yukon
Reprogram astrostart j5f tx2000
Get under the dash or where the unit is located.
You will see 8 or 9 dip switches on the unit with an LED beside them.
Turn switch 1 and 8 on.
Press and release the brake. (LED will flash)
Press and hold start button on remote. (LED will flash and parklights will flash once.
Turn switch 1 and 8 to off.
Press and release the brake (LED will flash once)
In future would be a good idea to supply vehicle details etc as can sometimes be a known condition , that saves time looking it up , good luck
Nov 18, 2014 | Cars & Trucks
Astroflex car starter Tx2000
Try posting to Cars & Trucks for a Auto expert.
May 11, 2013 | Cars & Trucks
Python 476p
May depend how it was programmed. My Python 476P was setup with Lock and Unlock pressed to get it to remote start. Then, get in the vehicle, put the key in the "on" position and press lock / unlock to get it to end the remote start cycle. Then Drive off ...
I got a second remote, followed some directions via YouTube to program. Key in the on position, then hit the valet button once, then press and hold. One chirp, hit lock on remote. Let go of valet button . Press, then press and hold, two chirps. Hit unlock. Continue for 3 (aux) and 4 (panic). End result was Lock would also unlock. Unlock did nothing. And Aux started the remote start sequence.
Having bought a vehicle used, then no manual made this a bit difficult. I will continue to test alternate programming to try to match the original remote so accidentally firing up the rig doesn't happen. My suspicion is I have to maybe do Lock, Aux, Lock/Unlock, panic instead. Good luck.
Oct 30, 2012 | Python Vehicle Parts & Accessories
Astrostart J5f Tx2000
You might want to post this question in a different section. This is the computer games section.
Jul 22, 2012 | Computers & Internet
I bought a 2007 Camry with a remote start. The seller doesn't know how to start the car with the remote. The remote is a 4 button Viper 474V.
First, be sure that the remote is programmed for the vehicle by using it to operate the door locks(pressing the lock and unlock buttons). The parking lights should flash if nothing else works.The usual way to operate the remote starter with this remote is by pressing the * button once but, the option could have changed if the remote has been reprogrammed differently. So, try pressing the * button once. If this doesn't work press it twice within two seconds.If this doesn't work try pressing the lock and unlock buttons at the same time. If these steps fail to initiate the remote starter try the steps listed for the * button with the aux button. If either of the remote starter inhibits (hood pin, neutral safety) are active you should receive flashing parking lights for a failed attempt to remote start.
Jan 16, 2011 | Remote Start System
Remote starter does not work but will unlock and lock doors.
Dec 08, 2008 | 2005 Pontiac G6
Vehicle Parts & Accessories Logo
593 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
