Question about Sabio Storage DM2-P 2-Bay 2.5" Hard Drive Enclosure with 1TB Hard Drive, RAID
Fixya has turned into a POS... - Sabio Storage DM2-P 2-Bay 2.5" Hard Drive Enclosure with 1TB Hard Drive, RAID
  • Sabio Storage Master
  • 27,725 Answers
What is the issue can you elaborate ?
Posted on Jun 11, 2014
92 camry. When turn key to shut off engine the key will not go past the ACC pos. Will not go to LOCK pos to remove the key. Have to disconnect the battery to turn key to LOCK pos. What is the fix?
Park shift interlock. A safety device that will only allow the key to be removed when vehicle is in park. It is malfunctioning could be as simple as a cable sticking
Feb 11, 2017 | Toyota Camry Cars & Trucks
PEA is on the screen and no keys work
stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
Nov 26, 2015 | Retail Supplies
My 77 Chevy c30 has no power. Jumped started it and drove it home. I turned it off then tried to restart it. No power no lights. nothing. Battery is good. An u help will be appreciated.
If the battery is good you will need to follow flow. Test light is the easiest to use. First hook light to ground and touch pos terminal,lights good next touch pos battery cable end, lights good. Next follow pos cable to starter pos terminal,lights good. Next hook test light to bat pos teminal,touch neg terminal,lights good. Then touch engine block, lights good ground. Next move test light clamp back to ground/neg side and touch alt pos terminal,lights good.if all that tests good, if all good move inside and check for power at ign switch pos term if at any time you dont find power you have wiring issue that needs to be addressed. Let me know what you find. Russ
Mar 29, 2015 | Chevrolet Cars & Trucks
Need color code for kenwood kdc mp 245
black - ground, red - switched or ignition, yellow - constant (memory) power, white - left front spkr pos., white/black - left front spkr neg., gray - right front spkr pos., gray/black right spkr front neg., purple - right rear spkr pos., purple/black - right rear spkr neg., green - left rear spkr pos., green/black - left rear spkr neg, blue - antenna remote, blue/white amp remote turn on.
Nov 02, 2010 | Kenwood KDC-325 CD Player
When installing a power inverinto a truck should the ground go to the battery or to the chassis
Assuming truck is neg chassis/ground
Neg of inverter to neg of batt
Pos of inverter to pos of batt
Hope this helps
Thanks for using FixYa
Jul 04, 2010 | Vector VEC056D 2500 Watt Power Inverter...
My battery died on my key remote for my 2002 Ford Expedition. I have replaced the battery, but apparently need to reprogram it. How do I do this?
It should work even after taken the battery out., but here is the process.
1. place key in ing.
2.turn from position 2(lock) to pos 3(off), cycle pos 3 to pos 4, 8 times within 10 secs. your 8th turn ending in pos 4. Doors should lock/unlock confirming the program mode is ready.
3. within 20 secs, program your fob by pressing any button on the fob. the doors will lock/unlock confirm it is programmed. If more than 20 sec pass before pressing the fob button, the step will have to be redone.
Feb 05, 2010 | 2002 Ford Expedition
Car stereo wire diagram for 88 toyota tercel
1988 toyota tercel sedan as follows
pink = (+) pos. for left front speaker
violet = (-) neg for left front speaker
light green = (+) pos. for right front speaker
blue = (-) neg for right front speaker
blue/yellow = (+) pos at all times (power)
grey = (+) pos. only in the accessory or run position
brown = (-) neg gound
red = (+) pos. right rear speaker
black = (+) pos. left rear speaker
white = (-) neg right rear speaker
yellow = (-) neg left rear speaker
verified at 2 resources . fixya
Dec 26, 2008 | 1988 Toyota MR2
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Sabio Storage DM2-P 2-Bay 2.5" Hard Drive Enclosure with 1TB Hard Drive, RAID Logo
81 people viewed this question
Top Sabio Storage Computers & Internet Experts
David Payne
David Payne
Are you a Sabio Storage Computer and Internet Expert? Answer questions, earn points and help others
