Question about Sears Refrigerators
Why 106 724240 sears coldspot feezer not going below 20 degrees?
  • 420 Answers
SOURCE: Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
Posted on May 26, 2009
  • 288 Answers
SOURCE: The 2 fans are not working but the freezer coils
the freezing is and temp are caused by the fans not working. One fan pulls warm air out of the box and across the evaporator coil, which in your case is frozen, and the other fan is used to pull air over the condensing coil which rejects the heat pulled out of the box. check the wiring diagram for a fan relay first, which can easily be changed out, or by some crazy chance, both fans quite working at the same time
Posted on Nov 27, 2009
  • 26 Answers
SOURCE: My ge Profile bottom freezer isn't freezing very
return it
Posted on Jun 12, 2010
jumptrout51
  • 3361 Answers
SOURCE: My freezer will not get below 20 degrees.
Here is the factory service manual.
cut and paste this pdf link.
http://136.166.4.200/contents/Fridge/LRSC26922xx/LRSC26922xx_Service_Manual.pdf
Check for ice on the freezer coils.
Check the Freezer fan motor.
Check the Compressor fan motor.
Posted on Jul 24, 2010
heatman101
  • 43501 Answers
SOURCE: my upright freezer temperature won't go below 20
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 26, 2010
What needs fixed in my built in Tappen oven, model 12-1263-30, when it is 90 degrees off?
Hello Wendy;
My name is Peter. I am a retired field service appliance technician.
The normal operation of a oven is the oven will rise 20-40 degrees above the set temperature and turn off. Then, when the oven temperature drops 20-40 degrees below the set temperature it will turn back on and cycle again. This is true except for the new accurate ovens.
Since you are getting heat your oven heating element is good.
You have a older oven.
Your problem is either the oven thermostat which cost over $200.00.
  • MFG Number 5303202782
25691587-pfxp0re3pkk4llvjptchxxrl-3-0.jpg Or, your oven control, which base on your oven age is no longer available.
Now, here are your choices:
1.) Take a chance and purchase the oven thermostat and install it. If this does not solve the problem you can return it less shipping and restocking charges.
2.) My professional recommendation is to put the old girl to rest.
You can:
a.) Go to a Sears Outlet (Scratch and Dent) Store, save a couple of hundred dollars on a new oven and still get a one year warrantee .
b.) Go to a used appliance store.
c.) Go to Habitat Stores - used appliance stores.
d.) Go to Second Chances Stores - Appliances removed from homes that were torn down.
Best of luck,
Peter
May 11, 2015 | Kitchen Ranges
I have a 2001 Kenmore Coldspot that is having temperature issues. The freezer is fine but the fridge will not get below about 55 degrees. I have defrosted it already and also checked the air flow as...
Is the fan motor blowing from below? Does this model have a damper that opens and closes to allow freezer air into the fresh food compartment? Is the condenser area and kickplate clear of dust and lint?
May 18, 2011 | Refrigerators
Water drips from the freezer into the fridge.Upon disassemble, there is ice buildup under the coils. kenmore coldspot model #71184101
The defrost timer or the defrost heater element has probably failed. Go to the link below and enter your exact model number; you should find a line-drawing illustration and parts list for your fridge that you can use to locate these items and normally also determine how to remove or install them:
Sears PartsDirect
Apr 08, 2011 | Kenmore 52632 / 52634 / 52639 Side by Side...
Fan motor keeps kicking on.
You must have a bad compressor relay
Dec 22, 2009 | Refrigerators
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Location of start relay
yes that is an ok price or try coast appliance if you are in the la area ok the relay is located on the left side of the compressor is conected on a 3 pin conector you can't miss it is mounted on the compressor it self
Nov 28, 2008 | Refrigerators
Kenmore 14.8 cft - temperature between 5 and -22 degrees (-15 and -30 C)
Big...this is likely normal. I'm not sure where you're measuring that temp from. If it is the fan outlet, this is possible. The fact that the unit is staying below 5 degrees means that it is within spec. You do have a warranty. Ask Sears to come on in and check it out.
Your 'duty cycle'...that amount of time that the compressor is on should be about 20% of a unit of time...say 25 minutes out of 2 hours. Is that about right? If so, enjoy your ice cream.
Dec 01, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Refrigerators Logo
93 people viewed this question
Top Sears Refrigerators Experts
geob91
richie46
Are you a Sears Refrigerator Expert? Answer questions, earn points and help others
