Question about GE Ovens
Kenmore oven 326b1016p001
What is the out side foam casing called?
I need a wiring schematic for a Kenmore model 79040522400 wall oven . Control panel the five wire that hookup on side for broil, bake, etc
diagrams are inside the control panel, usually in an envelope to the left or right side of center. If not there, look on the top or rear panels as they may be adhered to either of those. Worst case is someone took them from the unit during service in the past and never replaced them. Last option is to look online at sears parts direct. They show the diagram, but it is not clear.
Jan 26, 2015 | Kenmore Ovens
Kenmore gas oven 326b1016p001
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 03, 2014 | Kenmore Ovens
Oven won't heat up
When you set the temp, look for an orange glow by the burner. If it isn't there the igniter is bad. It is electric and stays in the flame so it will go bad with time.
Jan 24, 2014 | GE Ovens
Instead of using the self cleaning option on my kenmore electric oven,what can I use to clean out the oven manually?
We have caustic aerosol manual oven cleaner foam sprays which are available at all out supermarkets amongst the cleaning materials. You may have something similar?
Mar 21, 2011 | Ovens
How do I change the lightbulbs in the oven
Make sure the oven is off and cool (turn off the circuit breaker). Wear a leather glove to protect your hand. Depending on your model, there may be a glass shield held by a metal holder over the lamp. In the case of a unit with this holder, press on one side to release the shield and remove it. Remove the bulb by turning it counter-clockwise. Replace with a 40 W appliance bulb (turn clockwise). Replace the glass shield and the holder. (On some oven models, the shield will twist on and off like a bulb.)
There are several models of Kenmore 47783 Ovens; manuals are available here: http://www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+47783 .
I hope this helps.
(please note: never operate the oven without the shield in place if your oven has one.)
Dec 12, 2010 | Kenmore 47783 Electric Single Oven
ACCU BAKE codes come up e6 f2
You have the following error.
Cancel key drive line open
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore Ovens
Oven is beeping. Electronic controls do not respond. Error message F2 is displayed
Aug 21, 2009 | Kenmore Ovens
My GE 326B1016P001 is beeping and the display says "F7" I press off and the beeping stops. Then the beeping starts up again in a few minutes.
Mine does the same thing. It's the keypad circuit board/heat sensor. They aren't happy with moisture coming from the oven. Mine it 12 years old and I'm replacing both.
Jan 15, 2009 | Ovens
Oven shows F2, door locked, keeps beeping
Jan 06, 2009 | Kenmore 42161 / 42169 Electric Single Oven
Ovens Logo
18 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
