Question about Minolta EP1083 CS/PRO Copier
Error COF30 After copying 100 pages without problems on a donated Develop 1500 copy machine the error COF30 occured. It looks like it is a error located on the toner sensor. How can I clean the sensor to get this error fixed? Please submit a solution for this error if you know one. The machine is now used in a non profit music club with no money. So I need a cheap solution. Would be great if someone knows how to fix this. Thanks for your help / suggestions in advance!
  • specialties plus
    specialties plus May 26, 2014
    on the 1083 you need to get into service mode as soon as it allows you to input before it runs and throws code . go to adjust mode change adtc setting only a few numbers at a time . until it stops throwing code. make a copy and determine if it is overtoned or not, if it is lower the number a few at a time and run sky shots . once you get the toning where you want it run f8
  • Minolta Master
  • 1,297 Answers
This code to refer on ATDC sensor malfunction.Check the ATDC sensor(auto toner density control) and the connection between the imaging unit and copier,replace the PWB-A board or replace the ATDC sensor.If the copier machine have more 120000 copies change the developer and perform the F8(ATDC level control process).
Posted on Oct 03, 2009
    President:
  • Minolta Master
  • 1,447 Answers
It is the problem your copier fuser unite thermostater it clean or change heat roller
Posted on Jul 10, 2009
  • 92 Answers
Toner sensor cannot b cleaned have to replace it
Posted on Jun 26, 2009
Hp laserjet m1005 initializing problem
The wizard did not successfully complete copying your picture because an error occurred.
See details error information. The following problem occurred while copying picture: Unspecified error
Oct 31, 2013 | HP LaserJet M1005 All-In-One Printer
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I am having HP 2300 LaserJet printer. From Yesterday it started printing continuously. When you give one test page from XP It will print that Test continuously without stopping. I need to cancel the Job...
Hello .
First select the configure device menu by up & down arrow keys in display select them by pressing green button find no of copies in sub menu change this value to 1 & set them by pressing the green button.Your value set to no of copies to 1 & your problem will be 100% resolved.
Sep 19, 2010 | HP LaserJet 2300d Printer
Describe your minolta 6001 error code cof30 Problem
Toner Density senor, located under the image developer assy. Clear by openning and closing the front door, if it comes back service technician required to replace developer, sensor, sensor board or mainboard. EP6001 is a legacy equipment may have a problem locating parts and supplies.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 23, 2010 | Konica Minolta Office Equipment & Supplies
Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Jun 05, 2009 | Kyocera FS-1118MFP Laser Printer
Minolta CS PRO black/white copier has error code
COF30 THIS CODE SHOWS THAT THERE IS PROBLEM IN AUTO TONER SENSOR.MAY BE IT IS DIRTY .CLEAN IT PROPERLY .OR REPLACE IT.PROBLEM WILL BI REMOVED.DO NOT FORGET TO RATE A SOLUTION.MIAN JEE
Feb 12, 2009 | Minolta EP1083 CS/PRO Copier
Blank copies down the centre of the page
pls check the drum charge grid and toner cardritge. may be the toner is empty or charge and transfer corona wire getin dust.
Jul 23, 2008 | Xerox CopyCentre C20 Black and White...
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Error 9-363
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
705 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
