Question about Radio Communications
Raymarine ray49e MY Ray49e Lcd display shows blank sometimes comes and disappears. This happens after it was opened to verify the code number.What can I do to fix it back?
  • 19 Answers
SOURCE: No LCD Display when opened at 90 degree
Dear sir, If the Picture in View finder is connect, then problem in LCD ribbon cable. LCD Ribbon cable may damage. Replace LCD ribbon cable. thank you, replie if any problem
Posted on Jan 17, 2007
  • 75 Answers
SOURCE: BLANK LCD SCREEN
The shutter in the lens is stuck closed. You need to take the camera to a shop where they will replace the lens assembly.
Posted on Mar 25, 2007
SOURCE: LCD display invisible on Sony ICF-2010
I found a posting that said this usually is a problem with weak memory batteries or a bad battery contacts. I replaced batteries and cleaned contacts and the problem was solved.
Posted on Mar 10, 2008
t00nz
  • 4738 Answers
SOURCE: Blank LCD screen
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Posted on Mar 15, 2008
EricDaniels
  • 80 Answers
SOURCE: Firefox address bar disappears
The theme is probably bugged with 3.0.5. Try using a similar theme and see if you get the same issue. Or reinstall the theme as you may have corrupt files.
Posted on Jan 30, 2009
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
94 deville concours ac works sometimes then u here duct door close and digital climate temp numbers go to blank dashes and defrost comes on and is stuck wont turn off then digital numbers come back on
My first guess would be a wiring problem or the controller.
If anything goes wrong with the system, it will default to the defrost mode for safety.
Jul 10, 2012 | Cadillac Cars & Trucks
N70, cell is on,lcd ok but not display.
That should be hardware problem, maybe your display is bad, or maybe display ic isn't functioning properly or display connector's problem. Sometimes only cleaning will fix this if there's no internal damage. Good luck.
Thanks for using FixYa.
Jun 12, 2010 | Nokia N70 Cellular Phone
Lcd blanks out
Yes, that is one possibility. It could be the cable from the motherboard to the display. Inverters are fairly common problem.
May 14, 2010 | Toshiba Satellite 1805-S204 Notebook
I want to mirror my Raymarine C80 on to a LCD monitor in Saloon, How can I do this?
You are unable to make that happen. The C80 displays are not able to be "cloned" or "mirrored". Sorry, but you would have to upgrade to the new C-Wide series or E-Wide series to complete the task.
May 02, 2010 | Raymarine C80 Multifunction Display
Lcd blanks out
It's either the "inverter" or some loose connections.
Either way, take the computer to a qualified technician to trouble-shoot, and/or to replace the LCD screen.
Mar 26, 2010 | Toshiba Satellite 1805-S204 Notebook
The display of the C70 has stopped working. Instead of a picture it only shows either vertical bands of color or just black/white vertical/horizontal lines. Occasionally the display comes back but only for...
I recognize the problem. It mostly occurs when the plotter is exposed to moist during some days. The contactstrip which connects the computer to the screen gets moist and does not conduct in an optimal way. The result is a non readable screen with stripes
The solution is simple: press on the edges of the screen and the contact is re-established.
Jul 18, 2009 | Raymarine C70 GPS Receiver
Where is the ray49 vhf radio serial number located?
its on the label on the underside of the unit. It will probably begin with E43035.........
May 04, 2009 | Raymarine Ray54 Vhf Marine Radio Dark Grey
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Radio Communications Logo
23 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
