Question about Ricoh AficioSP 5100N Laser Printer
Where is the fuser box located in a xerox work centre 4118x
Error 010327 in xerox work centre 5222
That error signifies a defective fuser unit. Replace fuser, part number 126K24980.
http://www.iteminconline.com/126k24980_126k24980-126k24981-126k24982-126k24983-126k24984-xerox-workcentre-5225-5230-fuser-110v-new.htm
Feb 22, 2016 | Xerox Office Equipment & Supplies
My xerox work centre 4118 is locked How am I going to unlock it
Do you mean your "Scanner" is locked? Were the paper exits to the left of the opening there should be a sliding switch. I suggest that you should use a flashlight to locate it This is the locking mechanism that once toggled , it will unlock the scanner. Remember to turn-off the printers power before attempting this.
I hope this resolves your problem, Steve
Nov 06, 2015 | Xerox WorkCentre 4118x multifunction ( fax...
Document jam
Check paper path. Open right side door and check paper tray and fuser unit.
Dec 09, 2011 | Xerox WorkCentre 4118x multifunction ( fax...
Open heat error
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Nov 24, 2010 | Xerox WorkCentre 4118X All-In-One Laser...
Problem scanning with a Xerox 4118x printer
you might have to configure the scanner manualy
May 24, 2010 | HP Jetdirect 175x Print Server
Error message open heat error is appearing how do i fix the problem?
The fuser will need to be replaced. There is a web type heating element in that fuser that goes bad.
Feb 18, 2010 | Xerox WorkCentre 4118X All-In-One Laser...
Open heat sensor
Bad fuser . There is a heating mesh in the heat roll that opens.
That requires replacing the fuser.
You can call Xerox or google a business called The Parts Drop and order it there. I would recommend The Parts Drop. Have done business with them for years. best in the business.
Feb 09, 2010 | Xerox WorkCentre 4118X All-In-One Laser...
Workcentre 4118 open heat error
Bad fuser module. There is a web mesh heater in that heat roll that goes bad.
Jan 16, 2010 | Xerox WorkCentre 4118X All-In-One Laser...
I have a Xerox Copier Document Centre 350 it has a fuser error U4-1 How do I reset fuser as the copier will not work as it says call technician
I would truly call in for service. Copiers require a trained tech to replace the fuser. Trust me I work in the IT industry. Have a trained tech fix it.
Nov 23, 2009 | Xerox Document Centre 420 DC Laser Printer
Ricoh AficioSP 5100N Laser Printer Logo
13 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
