Question about Funai NB530SLX Blu-Ray Player
Funai bluray player nb620fx4 will not connect to netflix
How do I reset my funai blue ray player to factory settings?
Macgo Windows blu-ray Player, with detailed Menu for you operate, and you can reset to factory setting easily. You can try for free.
http://www.macblurayplayer.com/windows-bluray-player.htm
Nov 17, 2014 | Funai Televison & Video
Funaii bluray player won't play my bluray disk at all what do I do
There could be several issues but it would be helpful if you had provided the model number of your Funai player.
Possible causes provided all the connections are ok.
Make sure that the disc is playable on this unit.
Check the region code of the disc. This unit supports the following region codes.
- Blu-ray Disc "A"
- DVD: "ALL" or "1"
For DVD-RW/-R, make sure that the disc is finalized.
Clean the disc.
Is the disc a newer title? This problem may be solved by software update. Find out if you unit has the latest software version.
Funai 50 years of Excellence in Consumer Electronics
Aug 06, 2014 | Televison & Video
I have Netflix on my iPad so how do I get to watch movies on my tv?
You need a wireless or wired internet connection into the TV or another device that connects to the TV like a blu-ray player with Wi-Fi included. Once you have the bluray player installed, then you access their menu and install their apps. Each bluray player is different so you would have to answer back with a model and manufacturer to give you specifics to your model.
Jan 03, 2014 | Netflix
How do i get my netflix activation code for my Samsung bluray?
After you have successfully connected your bluray player to the internet either by connecting it directly to your modem, using a wireless adapter to connect it to your modem wirelessly, or connected it to your phone jack in the wall (dsl), you will be able to use your bluray player's remote to navigate to the part of the menu where you can access netflix. When you select netflix and go through a prompt or two that you'll be directed to you'll get the activation code. You will then go to your computer or smart phone and go to www.netflix.com/activate where you'll enter the code. Then your bluray player will be ready to stream netflix. Then when you go back to the netflix area of the bluray player you'll be prompted to enter your netflix login (username and password).
Aug 18, 2011 | Televison & Video
Funai NB530SLX Blu-Ray Player Logo
407 people viewed this question
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
