Question about Epson Stylus C88 InkJet Photo Printer
HOW TO CLEAN AN ink heads on epson c88 - Epson Stylus C88 InkJet Photo Printer
websnail
  • 419 Answers
SOURCE: ink heads
Removing the printheads from Epson printers is not recommended as you can successfully clean them while they are still installed and with less chance of borking the printer by forgetting where that screw went :)
To do this you need to turn the printer on, let the printhead move off the parking pads (where the printhead rests) and then immediately pull the power cord so the printer stops.
This will allow you to freely move the printhead to the far left out of the way.
You now need some ammoniated windex or a similar cleaning solution (try asking your ink supplier) compatible with inkjet printers.
Using a kitchen paper towel, carefully fold it four times and then soak this in the solution before putting the paper pad so it sits over the parking pad. Now move the printhead so it sits over the solution soaked pad and leave for 12 hours (don't turn the printer on or plug it back in).
Remove the original pad and put in a new one and leave for a further 12 hours.
Note: This approach allows the cleaning solution to wick up into the printhead nozzles and break down the clogs, returning them to solution and allowing you to clear them out. It requires time to let the solution do its work which is why it's critical you don't try to rush things..
Now, remove the pad, plug the printer back in and turn the printer on... Wait for the printer to stop it's initial routine and then run a cleaning routine and a nozzle check...
Leave the printer for a further hour just to let things settle some more and then print a new nozzle check...
You should find that that the printhead will have cleared out a great deal of clogging.
If your printhead has been clogged for some months you might want to change the pads more than once and extend the period over 2 to 3 days.
Whatever you do, don't try brushing the printhead back and forth over the soaked pad and avoid more than one cleaning cycle in a 3 hour period.
Hope that helps.
Posted on Mar 09, 2009
gwbm
  • 353 Answers
SOURCE: EPSON Stylus C88 Series not printing blue ink
From the lack of interest by koolcorgipro in this problem, I think we may say it has been solved by the poster.
Posted on Mar 26, 2009
tigertail
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
cq92
  • 184 Answers
SOURCE: Heads will not clean
Usually the simple way to clean old ink from heads is to get a container of alcohol from the drug store and either using a Q-tip or paper towel soaked - wipe the print surface of the head to remove the old ink, then run the head clean utility once after. If you cannot reach the head surface, move the print head to change ink position, unplug the printer and fold and lay the paper towel soaked in alcohol under the head and manually move the head back and forth by hand to clean it. You may need several sheets of towel and alcohol to do this. Fold the paper thick enough so it will touch the head surface to clean.
Posted on Oct 26, 2009
Testimonial: "Great Solution"
Rossiman46
  • 50 Answers
SOURCE: epson C88 will not print, is flashing both paper and ink lights
I think you need to reset the counter, you can either take it into a epson service centre & have them reset it, or download a programme online.
you just need to google it, just type in service reset C88 that should do the trick.
Posted on Nov 06, 2009
Epson stylus c88 red ink prints yellow
print a check of the nozzles, and check what colour (magenta) is not working. If the cleaning part does not help, perhaps you should put a new cartridge in, or clean again.
Feb 17, 2015 | Epson Stylus Office Equipment & Supplies
My Epson c88 was working fine. I changes ink cartridges and now the black will not print.
Your printer head may be closed.To remove the problem jast open ink cartrige from the cartrige chamber. set a seringe with full of black ink into the plustic pin which are tidely insert in the ink cartrige. After push 2/3 time your printer work fine again.
Thank You .
Shohagtush
Oct 20, 2010 | Epson Stylus C88 InkJet Photo Printer
I've replaced the ink cartridges on my mother's Epson Stylus C88 printer and it prints only green. Any suggestions?
Epsons usually give you an option to "clean the heads." Look for any Epson software on the computer, or it might be hidden within the "Properties" of that printer (in Control Panel).
May 17, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 - New Epson Factory ink cartridges. Nothing prints, although printer goes through the motions of printing. What could be wrong? Ink levels are fine.
You should run a nozzle check to verify if the heads are printing all the inks correctly. If the pattern is incomplete you need to run head cleanings.
Apr 30, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson Sylus C88 prints but there is no ink coming out
Have you tried cleaning the print head? A couple of times anyway and test print. If you use generic sometimes you'll need to clean print heads more often than if you used epson ink.
Jan 06, 2010 | Epson Stylus C88 InkJet Photo Printer
EPSON PRINTER PRINK HEAD PROBLEM
Problem with ink flow. Use original ink or compatible? If original, ink will out and dried after head cleaning many times. If compatible, problem is ink quality. When head cleaning, ink flow to head by suction of head cleaning mech. If use to print, ink at head spray out, but ink ank ink tank not flowing good to head.
Jun 28, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson c88 prints horizontal lines
It looks like storm_christ has lost interest in this problem, so we may call it "solved by poster".
Apr 06, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson stylus C88 won t print color ink black is
Apr 02, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson c88
Sounds like print head issue; have it serviced or u can try this :
How to Unclog Epson Print Heads
Jan 24, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 InkJet Photo Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
