Question about Hitachi 46GX01B 46" Rear Projection Television
Hitachi tv clu572tsi is having triple pictures coming up
I have a hitachi ultravision digital hi-def TV model number 53UDX10B from December 2001. The words in its own menu and from my cable box menu are distorted, as well as some words appearing in commercials,...
The tv problems known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UDX10B 53" Rear Projection...
My hitachi digtal camera hdc-570ap not switching on red led blinking other buttons not responding
You probably aren't using high power Triple A batteries. Try using Duracell Ultra high power batteries instead.
Apr 04, 2010 | Hitachi Cameras
Hitachi projection TV Model 43F300 has no picture or sound?
did you ever find solution to this? I have similar problem.
Mar 28, 2010 | Hitachi Televison & Video
The screen looks like I need 3D glasses to see the picture. What part do I need to fix this?
Depends on the set, but it sounds more like your projectors have come out of alignment. Hopefully this isn't washout due to a failing emitter or projector. I would let a certified TV tech check the set for alignment since rear screen sets are very dangerous. All three projectors have their own HV cap and flyback, which triples the chance that you will get zapped.
Mar 09, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Double vision
I have a 60SBX72B and the colors are all separated like triple vision. Is there a way that I could fix this
Jan 07, 2010 | Hitachi 50UX57B 50" Rear Projection...
Our Hitachi tv turns on okay but the picture on comes in for 2-3 seconds and then the screen goes black. Last night the tv work just fine but this problem started today as I turned the tv on to watch...
I don't know what model you have,but... I have a 50v715 and it was doing the same thing and it turned out to be the lamp. So if you have not replaced the lamp in a while then it could just be it time. Hope this is helpful.
Oct 03, 2009 | Hitachi Televison & Video
Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Mar 12, 2009 | Televison & Video
Rear view projection t.v
Hello riff5000719,
The problem with your TV might be the convergence correction amplifier modules (2 STK392-110). These modules often malfunction and produce the symptoms you are describing. The cost of the parts is about from $12.00 - $32.00 depending where you buy the parts from. The major cost will be the labor, and if needed the cost of installing the biasing circuitry that the modules use. This usually costs around $200.00 - $400.00 depending on the shop.
Getting rid of it might not be warranted if you can spend the 200-400 to get it repaired.
I hope this helps,
Thank you,
Shuttle83
Sep 28, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 43FDX01B Convergence Problems
Hitachi remote part # HL01643........I like the original remote
to do adjustments.................T.
Aug 06, 2008 | Hitachi 43FDX01B TV
Hitachi 43fwd20b blurrs help
Hi, it needs convergence IC`s and possibly a few low Ohm resistors, not an easy fix for a layperson, usually costs 250- 300.00, hope this answers your question, if not e-mail me back, good luck, BMW Rider
Feb 09, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 46GX01B 46" Rear Projection Television Logo
15 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
