Question about Artic Air Arctic Air F22CW12 Commercial Freezer R134A 1-Ph 32"x32"x74"
How do i add freon to the below freezer?
I am troubleshooting the above freezer. It blows warm. Is there a freon recharging port? What other common problems do they have?
How to add 134a to magic chef deep freezer
First your freezer does not use R-134a. That is for auto air conditioners only. It uses R-12. You need refrigeration compound gauges, R-12 refrigerant and a two devices that connects to and punctures the lines and gives you a port to connect the hoses from the refrigeration compound gauges. You must have a refrigeration leak if you need to add refrigerant. The leak needs to be repaired or you will lose the refrigerant in a short time again.
Nov 08, 2015 | Magic Chef Chest Freezer MCCF5WBX
Whirlpool freezer cool air but not freezing?
Check the seal first. Then check the freon. If it's R-12, you can go to the auto parts house. They have a bottle with a hose to add freon. You put it in on the "suction" low side with the unit running. you can tell when it has enough by feeling the low line be cold and teh high pressure line is warm to hot
Jun 06, 2014 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Where and how to add freon to upright freezer
I did one earlier this summer. Took some pix. Check this out: Freezer recharge
Oct 23, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
How do i add freon to system
Get a saddle valve like THIS ONE. Sand down the suction line or compressor ear and attach the valve. Connect hoses to the valve and add some freon. The low side pressure should be around
5 PSI.
Sep 30, 2010 | Magic Chef Chest Freezer MCCF5WBX
I cannot find the location to add freon to my frigidare uprifgt freezer model number-ffu16f9cw1
Most freezers do not have a tap from the factory to add aditional freon...you will need specialized equipment to be able to do that...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 02, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
The kenmore 20 frostless deep freezer is cold in the lower section of the freezer but the upper half is warm the setting is maxed out. the air that is blowing across the coil appears to be warm. that leads...
The evaporator coil must be lightly frosted from the top to bottom. This proves that all of the r-134a freon is still present in the system. If you visiblely see that it is not (half frosted the other half warm?no frost) then this is a sign that the r-134a freon has leaked out. Another way to determine for sure is to use refrigeration gauges to check the pressure.
let me know what you found then we can take it from there... hope this was helpful
Apr 05, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
12 year old freezer won't get above +20. Could it be the temp control dial?
I think you meen below 20 . Its mostlikely low on freon. if only half or less of the evap coil has frost , you low on freon. Then you have a leak in the system.
Dec 01, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Does not seem to be cold enough ten yrs old
Hi, first check your coils on the back and make sure they are clean, then check the cover on the front bottom and make sure it is clean. If it is all clean and still running warm then it may need to be recharged with freon. At that point you should contact a heating/cooling technician to come out and recharge your system. They are the only ones licenced to handle the freon to recharge your cooling system on the fridge.
Aug 11, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Hotpoint 25.3 cu. ft. not cooling
When the freon as been recharged, did the dryer been replaced?
Nov 25, 2007 | Hotpoint 6.67 cu. ft. / 189 liter Chest...
Artic Air Arctic Air F22CW12 Commercial Freezer R134A 1-Ph 32"x32"x74" Logo
66 people viewed this question
Top Artic Air Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you an Artic Air Freezer Expert? Answer questions, earn points and help others
