Question about Compaq Evo D310v PC Desktop
My compaq evo d310dt keeps asking for a boot diskette in drive A.
Every time i tried booting on my system,its keeps displaying the above message and rearly boots on when its beeing disturbed. Th e solution to hiramnaphtali@ymail.com pls,. thanks
  • 212 Answers
You need to set the primary hard disk as the first boot device in the BIOS's boot settings.
Posted on Jun 22, 2009
Every time the system is turned on it says Non-system disk or disk error, replace and strick any key when ready. There are no disk in the disk drive or the sd drive. No matter how many keys you strike...
Your computer tries to "boot" from various devices:
* bootable files on a USB memory-stick or SD memory-card
* from 3.5-inch diskette drive (if installed)
* from CD/DVD disk
* from your disk-drive
Your computer tried to boot from your disk-drive, but FAILED to do so.
Since the disk-drive is "dead", it tries to boot from any of the other devices,
and displays that error-message when it cannot boot.
So, your disk-drive has "died". Ouch!
You need to purchase a new disk-drive, and reinstall Windows onto it.
Dec 23, 2010 | HP Compaq nc6000 Notebook
The power light is on, but the monitor is off
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
 - Floppy drive
 - CD drive
 - Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Or:
Cause:
This is an expected operation. In the Boot Device priority setting in BIOS, you will see Removable Dev. (floppy), Hard Drive, ATAPI CD-ROM, and typically last is Intel® UNDI PXE 2.0. This setting will attempt to boot off a remote agent using the onboard NIC. By seeing this message it means the PC cannot find a boot partition on the floppy disk, hard drive or the CD ROM to load the operating system. Solution:
Install an operating system or put in a bootable device into the floppy or CDROM. If you do not plan to boot to a remote boot host, you may disable the Intel® UNDI PXE 2.0 option from the BIOS setup utility boot order. Relevant Information: No operating system installed
C drive does not have an operating system loaded
No bootable floppy diskette in diskette drive This applies to: Intel® Desktop Board CA810E
Intel® Desktop Board D810E2CA3
Intel® Desktop Board D810E2CB
Intel® Desktop Board D815EEA/D815EPEA
Intel® Desktop Board D815EEA2/D815EPEA2
Intel® Desktop Board D815EFV/D815EPFV
Intel® Desktop Board D820LP
Intel® Desktop Board VC820
End of Interactive Support Announcement
These products are no longer being manufactured by Intel. Additionally, Intel no longer provides interactive support for these products via telephone or e-mail, nor will Intel provide any future software updates to support new operating systems or improve compatibility with third party devices and software products.
THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.compaq.com and/or developer.qompaq.com
Comment by Beni S-P, posted on Oct 26, 2007
And i forgot :
check power suplay and ram???Let me know if u get help???
Oct 30, 2007 | HP Compaq Business nx7010 Notebook
I have faced a problem on Compaq Evo W4000 that there is an error i.e 1801 microcode patch error so how i can remove that error
Give a try to update BIOS. Click here and follow the intrsuction
  1. Obtain a formatted 1.44-MB diskette and place it in your A: drive.
  2. Download the SoftPaq to a directory on your hard drive. The file that is downloaded is an executable with a filename based on the SoftPaq Number above.
  3. From that drive and directory, execute the downloaded file and follow the on-screen instructions to build the ROMPaq diskette.
  4. Place the newly created diskette in the A: drive of the computer to be upgraded or restored and cycle system power to boot from the ROMPaq diskette.
  5. Follow the on-screen instructions to select the Compaq System ROM and flash the firmware. WARNING: DO NOT TURN OFF POWER OR ATTEMPT TO REBOOT THE COMPUTER DURING THE UPGRADE PROCESS!!!
May 10, 2010 | HP Compaq Evo w4000 PC Desktop
Compaq Evo N1020v operating system not found. I dont have recovery disk and also it dosnt seem to pick up xp when I insert into CD Drive. What could be the exact settings to boot from CD Drive?
Make sure that your CD is Bootable. Now you will need to do settings in BIOS to boot from CD..
1. Power ON the computer and Press "Delete Key" or F1 or F2 or F10 Key to enter in BIOS.
2. Goto Boot Menu Options
3. Select First Boot Device to CD / DVD
4. Second Second Boot Device to HDD
Now Save Settings and exit . it will reboot computer . If your CD is bootable then it will ask to boot from cd message.
Option 2 :
You can try by pressing F12 or F11 key simultaneouslty after power ON computer. It will display Boot Menu so from there you can select "CD/ DVD Drive " and press enter then it will boot from computer.
It will glad to help you further if your problem doesnot get resolved.
Mar 28, 2010 | Compaq Evo N1020V PC Notebook
The COMPAQ splash screen displays, with F1-Setup and F10 system recovery option, but then displays 'DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER'. This is my sisters computer, and she says there...
You may be able to purchase a system disk from Compaq, otherwise, try any generic XP disk. It won't have any Compaq drivers, but at least you can reformat the C: drive and get XP on it.
Nov 27, 2009 | Compaq Presario S6300NX PC Desktop
On Armada M700 when I try to install windows XP a note tell me there is a disk controll error, soon it goes away, and when I insert the system diskettes on the 4th disk it will not go dfurther it says...
- Floppy drive
- CD drive
- Hard drive
At the A:> type fdisk <press enter>
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:>
Once at the A:> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
All users
Oct 16, 2009 | Compaq Armada M700 Notebook
Compaq n620c evo laptop
Check your floppy drive and see if there's a disk in it and remove it. If there is no diskette in the floppy drive and you are still getting the error. You can go into the Bios and turn off the "boot from floppy drive", that way it will not look for the floppy drive when booting up. Hope this helps.
Feb 27, 2009 | Compaq Evo N620c Notebook
Misplaced rompaq diskette
You probably need to change the boot order in the bios to make the computer boot from the cd rom before any local hard drives.
F2 is usually used to access the BIOS, you have to press it immeadiately upon seeing the first screen, which usually displays the name of the manufacturer, and from there you have to find the section to change the boot order.
Dec 08, 2008 | Compaq Deskpro EN PC Desktop
Compaq evo-d510-boot problem
change the boot sequence in the bios setup into
HDD
CD drive
Usb
Nov 18, 2008 | Compaq Evo D510 Minitower (Open Box)...
Unplugged my armada m700
 - Floppy drive
 - CD drive
 - Hard drive
All users
Oct 28, 2007 | Compaq Armada M700 Notebook
Compaq Evo D310v PC Desktop Logo
208 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
