Question about Canon Office Equipment & Supplies
Support Code : 300 The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
How do I make my mac recognise the printer again? i can see the printer installed on the mac and the printer is plugged in and turned on but somehow my mac doesnt know when i want to print. can you please help?
ginko
  • 19396 Answers
SOURCE: Hi! I'm getting the following message
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Posted on Sep 19, 2008
SOURCE: Error Number : 300 The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
I had this problem with a Canon IP5200R connecting to a Mac Book Pro running Leopard. I had setup the printer as per instructions using the setup utility, could print a test page using the utils but could not print from an app.
My solution was to delete the printer (System Prefs > Print & Fax) listed in the system preferences and then re-add by clicking the '+' in the pref panel, then selecting 'More Printers' from the popup window. If you have the printer connected to the network correctly it should show up and you can simply re-add it. My printing now works correctly.
Posted on Jan 25, 2009
SOURCE: canon mx850 series Error Number :
I had the same problem. I had moved my printer and when I hooked it all back up, there was an annoying clicking sound, the "in use/memory" light was flashing and there was no communication with my pc.
This is a tad embarassing, but if it helps someone, so be it lol. I had plugged everything in without looking.... my usb cable was plugged into the phone jack >.<.
Check all your connections.... then check them again ;)
Posted on Jan 28, 2009
  • 154 Answers
SOURCE: PixmaiP6700D:error#300. "The printer does
Error Code300--
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Mar 07, 2009
ksdi
  • 34 Answers
SOURCE: error 300 , problems printing
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
282
Posted on Mar 16, 2009
Mp 287 printer not responding
If your printer fails to respond to a job, check that all printer cables are connected properly and be sure that the printer is turned on. If everything is connected properly and powered up, go to the computer's "control panel" from the "start" menu. Choose "printers" and be sure that your printer is selected as the default. If everything checks out in the control panel, right click on your printer icon and select "properties." Click on the "details" or "port" tab and make sure that the correct port is checked off. Next, double click on the printer icon, which will bring up a list of current jobs in the print queue. Cancel all documents and try printing again. If your printer is attached by USB port, you may try connecting to other USB ports.```````````
Dec 27, 2017 | Canon Office Equipment & Supplies
Error c410, is it a serious problem ie costly to fix or how easy itto fix it?
That is a general printer error. Ensure that the cables are properly connected; you need to ensure that your printer is properly connected, and plugged in, and also the cable is accurately connected to the computer as well. Check the power; make sure that the printer's power is switched on, ensure that all the computer necessary computer components are also turned on. Make sure that the hardware is properly plugged in.
Jul 04, 2012 | Office Equipment & Supplies
Cannot print from windows7
Following are some of the tips, which you must follow while you are using a printer with Windows 7 system.
Make sure that the hardware is properly plugged in, and also turned on. Apply troubleshooting.
A troubleshooter is a tool, which is generated automatically and which can easily fix the problems that occur with your system.
Thus, if you are coming across different issues related to your printer, then you can consult the troubleshooter.
You require driver applications to run your hardware devices.
Make sure that the drivers are not outdated, corrupt, or incompatible, resulting in disrupting the communication between the printer and the computer.
Always make sure that you are making use of the most recent and latest device drivers, and also that are compatible with your system requirements and specifications, as this can be extremely useful in resolving printer issues.
Nov 24, 2010 | Epson LX-300 Matrix Printer
I have the same Error Number 300 with my Canon MX850 - it is connected by ethernet cable to my wireless router. I can scan documents OK, but when I go to print it says that the printer does not...
Hi Daniel, I just had a quick look and other people here have posted problems regarding error code 300 on the MX850. Take a look here when you get a minute to see if any of the solutions posted help you out at all. It's a long shot as this link is for Apple users but it might point you in a direction you hadn't yet tried. All the best.
Sep 30, 2010 | Canon PIXMA MX850 Multifunction Printer
My canon MP610 printer is not responding after replacing ink
Try switch of computer and printer if not in printer list of printers. Unplug usb cable and start computer without computer connected. Them switch off computer again and plug in usb cable and then restart and after started switch on printer and Windows should find printer as a new connection and then you may need your driver disc to reset up.
Mar 17, 2009 | Canon PIXMA MP610 InkJet Printer
Canon mx850 series Error Number : 300 The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
Nov 08, 2008 | Office Equipment & Supplies
PixmaiP6700D:error#300. "The printer does not respond. Make sure that the printer is plugged in, powered on, and properly connected to your computer." I've checked all of the connections and...
Error Code300--
1. Turn off printer
Sep 05, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Aug 28, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
67 people viewed this question
old marine
old marine
