Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Blacks out for 1-30 min. then back on. Standby light blinks 4x
This may be two problems but not sure. 1) the timer standby light always blinks four times then quits briefly then starts again even when the tv is off.
2) Generally the tv picture comes on but sometimes after a few minutes it will black out but I still have the sound. Then after 1 to 30 minutes it will come back on. I resorted to whacking it on the side of the box and the picture flashes on and back off.
What could this be? Sony kv32fv16
  • 668 Answers
I would suspect the circuit board around the HV transformer area to have a crack circuit print. Also look around in the vertical circuit for interment solder connections. But only do these things if you have some knowledge of TV circuit lay out. If you do not feel confident then call a professional. No sense in hurting yourself or damaging the the set worse.
Hope this helps,
Skyassoc
Posted on Jun 22, 2009
My sony trinitron screen goes black and the standby light blinks
How many times the standby light blinks at a time? Number of blinking of standby light with Sony Trinitron CTVs are fault indications. To know more about these blinks, and fault location, get in this site named Electro-help, and pull up older posts there. Try this link, and select the site.
Jul 11, 2012 | Sony Televison & Video
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
KV-32xbr400 switch problem
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it. in yor case you have 5 blinks that´s why the last is short to be possible the count..Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
May 18, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Standby light blinks and tv won't turn on
Four blinks = No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Dec 27, 2008 | Televison & Video
I have a sony trinitron Model kv27v65 that will not turn on. The standby/timer light blinks four times. It was working fine earlier today and we don't know what caused the problem.
Internally the 4 blinks means that the vertical deflection circuitry has Stopped.
This requires repair or replacement depending on your preference.
Sorry for the bad news.
Dec 27, 2008 | Proxim HOT-STANDBY PROTECTION SWITCH
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sep 30, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
215 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
