Question about John Deere Garden
JD LX188 Cuts off after 10 minutes only when mowing grass. Does not happen with PTO engaged but not under load.
I have gone thru the fuel system except carb. rebuild,Plugs new, Faint blue to yellow spark. Will run unloaded with Pto on or off and not fail, engage PTO and load by cutting some tall grass fails in 5-10 minutes. Wait 1-2 minutes and restarts.
2 Suggested Answers
  • 6468 Answers
SOURCE: pto cuts off while mowing
check the safety switches start with the one on the seat then the one on the clutch/brake pedal then the reverse cut out switch bypass them one at a time with a paper clip to test them also look for a loss connection at all the same switches
Posted on May 25, 2012
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Sep 15, 2015 | Toro 52" 27hp Z Master Zero Turn Lawn...
JD X595 4x4 mower - Starts OK, BUT, as soon as the brake is released, the motor cuts out.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
Mar 06, 2015 | Light Garden
How to fix JD x320 grass height level and blade engagement
Check if lever come unhooked or a stick or something blocking it.
Oct 21, 2014 | Garden
PTO stopped working. What can cause this to happen?
bad safty switch or bad switch or pto burned out pto cost 200.00 switch engagement 15.00 or bad safty switch 15.00 pto dont go out that often not unless your mowing heavy grass
Aug 29, 2014 | Garden
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
I have john deere lx188 rideon mower when i engage the pto the engine cuts out.
This sounds like a seat micro switch problem, make sure the block connecter is fully home and the switch depresses when you sit in the seat, if all else fails replace the switch
Dec 09, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
JD STX38 PTO disengages and melts the PTO switch? As I'm mowing along the blades disengage and then I push the PTO switch down and back up and the yellow button comes out and shows the bottom of it...
Electric Blade Clutch is shorted or if you are lucky the wiring to the clutch is grounded. Many times the wiring to the clutch is caught in debris or twigs etc. and pulls the wiring out and cuts and grounds it.
Aug 25, 2017 | Garden
While cutting grass the pto clutch cuts off, i have to push switch in and back out to restart blades. I have replaced the switch and pto clutch
Check operator present switch under seat. Perhaps you'r moveing and not staying on switch. Check wires to pto, and seat switch.
Aug 18, 2010 | Oregon Scientific Electric PTO Clutch for...
Mower blades engages but when I stop to empty grass they will not
yes it is there is one under the seat & under the dash & there is also one connected to the clutch/ brake peddle which is more than likely the one giving you problems is the clutch/brake peddle switch
Jun 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
15 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
